OFFICIAL MINI E-REVO THREAD!!!
#126
WA
RE: OFFICIAL MINI E-REVO THREAD!!!
My shocks and springs should be here soon. Waiting on the toe links. Has anyone tried the optional tuneable diff? How about the lower tooth pinion?
#127
HI
WOW! Your covered for the street.
WHO HAS PICTURES OF VARIOUS DIRT GRABBER OPTIONS!
IT8EZBNGRN: I gotz a 19T come'in in next week!
#129
My Feedback: (10)
IL
ORIGINAL: t9dragon
You are asking for serious trouble when charging the batteries using a Y-harness. The batteries will not charge correctly if you do it that away. It is best to charge them seperately. I charge my mini packs at 1-1.5 amps anything higher will shorten the life of the battery.
ORIGINAL: PrjctStrtFrce
I was just looking at the stuff I had and I was wondering if it would be ok to charge TWO batteries at once through the y-harness? Take the y-harness off the truck, connect it to the molex adapter, and hook both batteries to the charger. Would that be safe? If so, then what amp should I charge them at?
The 1700mah batteries that I purchased state that they should be charged at 2.8amps...so would 2amps be ok?
#130
NJ
I would love a set on bow ties or something similiar to that, that were the size of the stock tires. Id like a rim with a wider offset as well
#132
HI
ORIGINAL: KCMike
Man, these things are hot! My shop has one sitting in the case & it's callin' my name.
What's the point of the 2nd servo slot?
#135
IL
I just got my extra battery today. It is smaller than i thought it would be. But of course its a 1/16 scale, so what do you expect? But no sighn of the truck.
#137
ORIGINAL: andrewmac
It's here at last!!!! And they got it right this time!!!
#139
WA
19T - Curious how that goes. They supply a 23T. I haven't ran that yet. No need since all I have is 7.4 and its too torqy with the 28T buts its melting the batts.
Lessons learned. 28T pinion and 14.4V nimh -Bad
2 Nimhs (similaiar to 2S lipo) in parallel - better but wish it was faster.
Is 11.1 the answer? and then what pinion and will it be controllable? Gear down the motor stays cooler but torq is too much at least with stock suspension. Too much wheelie action.
The wheels are 12mm hex so any 12mm hex whell with fit. That means 1/10 on and off road wheels. I can't wait to see some post about tuneable diffs, springs and shock oils. Right now I feel like I driving a Tyco with a brushless cause the torq and the suspension is such an issue and I can't do anything till the parts arrive.
As it stands I paid $239 for that car, $75 for shocks, springs and toe links that haven't arrived yet. If I have to get a tuneable diff thats another $22 or something. I got 4 IB1600 Nimhs for $80. So I have about $300 the car and I'm itching to gett'r going good. 4th of July weeken I hope to have her ready to try at a makeshift BMX track. If things don't change I may be looking for a 1/12 Ofna Hyper STe. Cost is a little more but then If I keep adding the the Mini Revo it will be the same. If I could figure out how to fit 7 cell in that chassi I wouldn't need batts.
#140
I stopped by the shop on the way into work and bought the 1/16 Revo. I couldn't resist. It was $289 + tax. Mine is the #5 frequency. I'm charging the battery now & during dinner break I'm going to run it here in the office. Going thru the cubicle isles should be fun!
#141
HI
I will say this ONE MORE TIME! The stock TQ controller does not give you enough control options/features for this miniture bull!
Put your $75 into a good 2.4GHz or FM Transmitter. I have a Futaba 2.4 3PM. Dialed-In -100EXPO and I don't have the troubles many have with power delivery. I can go 1-2mph to 50, yet I can do forward and back flips if I grab a handful of throttle. The only other thing I did was dail-in the suspension for level jumps.
You can't enjoy this thing if you can't control it in the long run.
#143
HI
ORIGINAL: andrewmac
Hey guys, do you think that a Spektrum DX3R would be a good radio for this beast?
Isn't the DX3R the high-end of Spektrum's surface radios? However....
1. If it has at least an EXPO function and...
2. If its compatible receiver has the same dimensions of the Traxxas 4CH AM Micro or Futaba R603FS
Then......
WHAT ARE YOU WAITING FOR! CRANK UP THE EXPO AND ENJOY!
#144
ORIGINAL: it8ezbngrn
It comes stock with sealed diffs. I don't know yet if they put in grease or oil, but if its grease, just clean it out and add oil....
And yes a dx3r would be great.... Im going to use my dx3s....
#145
NC
Thanks for the advice guys! I think that I will put The Spektrum in and see how it does. I think that the shorter antennae looks the best anyway....
#146
Wow, I just ran it here in the building at work. The whole 2nd shift crew was impressed (as am I). This is my first brushless vehicle. Even with one battery I found it difficult to control, but with a little practice this improved. I ran it on carpet (the type in offices) and the grip was outstanding. I kept catching an edge and flippin' it over.
Pics to come ...
Pics to come ...
#147
mine shipped today... should be here monday, and my wife gave the OK to turn the back 1/3 of my yard into a track... Its about 50 ft wide x 30 ft deep so should be good... I got id desinged already... basicaly a flattened figure 8 so ther is a back straight and a front straight, and then the track has to jump over itself in the middle Just gotta get to work hehe
#149
ID
Got mine today! WOO HOOO I'm Love in it. So I ran a set of batteries . at 14.4 v and the motor got a little warm. I guess you do need to put the 23t pin. in. Going to go lipo should be better.
#150
1 Post
ORIGINAL: dacaur
