1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
OFFICIAL 1/16 VXL Slash thread.
Reply
Old 05-26-2010, 10:24 AM
  #301
katzcratch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OFFICIAL 1/16 VXL Slash thread.
is it a difficult replace for the axle?
katzcratch is offline
Old 05-26-2010, 10:49 AM
  #302
magnum500
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: katzcratch
i cant see any reason why that would be hard to do , should be a matter of a few screws . i wish i had mine i could tell ya exactly what to do .
magnum500 is offline
Old 05-28-2010, 11:28 PM
  #303
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i don't think i am understanding exactly what is happening, but my guess is part #7154 (small pin) is what is broken and you need to grab part #7151 to loosen the wheel nut. it should be fairly easy.
Foam Crazy is offline
Old 06-03-2010, 11:06 AM
  #304
katzcratch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks foam..I will try to drill off the nut and then get a good view... that blow up helps me visualize whats going on
Gonna be a pain to get that nut/bolt off
Old 06-03-2010, 11:29 AM
  #305
Ttam Says Blarg
Ttam Says Blarg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DOOD! dont cut nothing off yet.... did you try any kind of lubricants? IE. WD-40, 3-in 1 or all purpose oil?
Ttam Says Blarg is offline
Old 06-03-2010, 05:42 PM
  #306
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah... What I'm also saying is you should be able to simply turn the nut without having to cut off or drill anything. All you need is a grip on parts that are spinning so try that first and then go try other mehods. A small nut like that shouldn't be too difficult to negotiate with enough caress and torque. Good luck.
Old 06-03-2010, 05:52 PM
  #307
katzcratch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just ont know how I can grab the other side of the nut.. The space is too small, with the wheel there for me to get anything in loosen?
I think needle nose pliers may fit.. but thats it
will try more wd 40 as well
thanks
Old 06-03-2010, 06:00 PM
  #308
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suppose you can grab the axle on the side leading into the differential.
Old 06-05-2010, 12:57 PM
  #309
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i've been scratching my head about raising the body higher than stock levels. i went to the ace hardware store nearby and found some nylon parts to play with. it's a bit of a hack job, but i like how it turned out. this mod should give me more clearance for the larger wheels i'm running.
i've added a new futaba 3pmx radio system. it's nice and glitch free. i live in the suburbs, so it was okay to run it with the stock AM system it came with, but this new one is certainly nicer.
this particular setup does not need the wheel widener i've been using with the erevo wheels. i did however attach the modded HPI SS wheels with the barrel nuts the wheel wideners came with. the large nylon spacer is also from ace hardware.
ID:	1448219   Click image for larger version
ID:	1448220   Click image for larger version
ID:	1448221   Click image for larger version
ID:	1448222   Click image for larger version
ID:	1448224   Click image for larger version
ID:	1448225   Click image for larger version
ID:	1448226   Click image for larger version
ID:	1448227   Click image for larger version
ID:	1448229   Click image for larger version
Old 06-07-2010, 12:20 AM
  #310
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
... and here is one more set of images. these just arrived. the wheels and tires are HPI nitro off-road types with matching 12mm hex mount parts. as you can see, the wheels are diameter sized somewhere in between the slash and erevo wheels dimensions and the width too is somewhere in between.
i haven't glued them in yet, as they are a pretty tight fit. i'm going to run them unglued and see if that might work okay for bashing.
the grey wheel is also the same type of wheels and only different in the way it looks.
i'm using the wheel wideners on this setup. gonna run em tomorrow and will let you guys know how it works...
ID:	1449314   Click image for larger version
ID:	1449315   Click image for larger version
ID:	1449316   Click image for larger version
ID:	1449317   Click image for larger version
ID:	1449319   Click image for larger version
ID:	1449320   Click image for larger version
ID:	1449321   Click image for larger version
ID:	1449322   Click image for larger version
Old 06-07-2010, 07:32 AM
  #311
slashobob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i been looking for a replacement tire & rim for my slash I want to know what size 1/10 or 1/18 ..etc I do alot of onroad offroad bashing but i'm trying to get it set up for racing a my local track
slashobob is offline
Old 06-07-2010, 10:04 AM
  #312
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well bob, I think you're onto the money question. The thing we've all been trying to solve is the question you ask. While there is quite a bit that will fit a erevo, there is so little that will fit a slash. It'd be great if you can post what you find.
Quote:
ORIGINAL: slashobob
Old 07-24-2010, 05:50 AM
  #313
turok007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Q how can i get this thing to run on the road.
turok007 is offline
Old 07-24-2010, 08:03 PM
  #314
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: turok007
What exactly do you mean by "run on the road"?
t9dragon is offline
Old 07-25-2010, 06:47 AM
  #315
turok007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well at almost any speed all it wants to do is flip. would harder springs make a difference.
turok007 is offline
Old 07-28-2010, 09:04 AM
  #316
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slow down A LOT for turns. Or cut down some electrical tape into 1/2" strips and wrap the outer edges of the tires; this lets it drift a little.
FWIW, I finally caved in and converted mine to the revo suspension, though I still have Slash tires - yes, it looks a bit funny and the body needs to be trimmed.
BuzzBomber is offline
Old 07-28-2010, 10:40 AM
  #317
turok007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BuzzBomber
Slow down A LOT for turns. Or cut down some electrical tape into 1/2'' strips and wrap the outer edges of the tires; this lets it drift a little.
i have found a small area of off road and the truck is fantastic. but as i do a lot more on road i think i might have to sell it.
turok007 is offline
Old 10-24-2010, 08:23 PM
  #318
Graybug
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Noob here (to everything RC car/truck-wise). I've got a VXL on the way and I'd like to know any recommendations for "right away" upgrades. I plan on using it on dirt and asphalt (and dirty asphalt). Anything I need to change out early, or should I wait 'til something breaks?
Graybug is offline
Old 10-24-2010, 10:23 PM
  #319
dacaur
dacaur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Graybug
Noob here (to everything RC car/truck-wise). I've got a VXL on the way and I'd like to know any recommendations for ''right away'' upgrades. I plan on using it on dirt and asphalt (and dirty asphalt). Anything I need to change out early, or should I wait 'til something breaks?
The only mod I recommend is a second stock battery pack and a parallel adapter to more than double runtime. Oh, and get a wheely bar...
Keep the voltage stock or use 7.4v lipo's and you wont break anything anytime soon. It took my about a year to break my first part, which was a front control arm. I hit a pointed rock embedded in the ground with the front control arm at full speed... Well, actualy it broke the second time i hit it . The only other things that have seen damage is the wing (wheelies and cartwheels) and the body posts (from sliding on its lid) Oh and I lost about 50 body clips before I got smart and got some body clip keepers.....
If you up the voltage you can expect to go through differentials from what I hear.
dacaur is offline
Old 10-24-2010, 10:42 PM
  #320
Graybug
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, dacaur!
Graybug is offline
Old 12-04-2010, 02:56 PM
  #321
Biscuit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This tippy thing with the mini slash cant you just run a thicker oil in the shocks and tighten up the suspension to run on road.
Biscuit is offline
Old 12-04-2010, 03:52 PM
  #322
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Biscuit
Tried all kinds of springs including the revo springs, and oil up to 60 wt, with the stock tires and suspension arms I could never get rid of the rollover issue on asphalt - only thing that worked was wrapping the outer edge of the tires with electrical tape. I converted it to revo suspension arms and 1/10 buggy tires in the end.
Old 12-06-2010, 05:42 PM
  #323
dacaur
dacaur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea I think revo arms are really the only way to go... I dont really "get" the appeal of the slash.... my mini revo rolls over more than I would like, I cant imagine a slash....
dacaur is offline
Old 12-06-2010, 10:34 PM
  #324
Ttam Says Blarg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only way to get rid of the rolling issue is driving style. I also found if you drive it in dirt it slides instead of flipping. I think it is great fun trying to not flip it. I would assume its relatively realistic but hey..... I have never driven or seen a sct on asphalt..
Old 12-07-2010, 06:50 AM
  #325
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ttam Says Blarg
Actually FWIW, the CORR races I watched (when it was on a channel I actually get) usually had an asphalt section somewhere in the track, the front straightaway on the tracks that were built inside an oval track at least. I can't remember offhand which tracks they ran though, that was 2008 or 2009 season. I don't get the channel they're airing the TORC races on now, so I don't know if they're using the same track layouts......but I'm waaay off topic here.
Reply
Display Modes
