1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
OFFICIAL 1/16 VXL Slash thread.
Reply
Old 01-12-2010, 05:25 PM
  #201
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OFFICIAL 1/16 VXL Slash thread.
Quote:
ORIGINAL: Ttam Says Blarg
I only have a nimh charger and Im on a limited budget so im just staying brushed for now.
You can run the Mini Slash just fine on NIMH and brushless.
t9dragon is offline
Old 01-14-2010, 04:48 PM
  #202
Ttam Says Blarg
Ttam Says Blarg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
^ I know just not willling to drop 120 on a new esc and motor.
Finally got a response from RPM about parts for the slash.
"Dear Matt,
Unfortunately, there aren't any plans for 1/16th scale Slash a-arms just yet (they aren't the same as those found on the Mini E-Revo). We're using the Mini E-Revo a-arms as a feeler to see if the 1/16th scale market is strong enough to support a line of RPM products. Please give us some time to see how the market holds up and if it does well, I'm sure you'll see quite a number of new parts in 1/16th scale from RPM in the not too distant future.
Take care and thank you for your interest and support of RPM products. If you have any other questions or comments, please feel free to send us another e-mail."
Ttam Says Blarg is offline
Old 01-14-2010, 08:08 PM
  #203
patatchim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope they do parts for them soon. Although the car seem pretty resistant to hard bashing!
I have currently all my cars in the shelf, only using the slash!
It is quite awesome. Looks like a real truck and it seems like a real car when driving.
Kind like the need to reduce throttle input so the car won´t flip when hard turning.
patatchim is offline
Old 01-15-2010, 09:29 AM
  #204
Lurp06x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i bent my slipper pin and also ripped off my front body mount . broke the third one [:@]. but my question is how do you bend the slipper pin when its buried in the the middle of the chassis an has a receiver box an motor protection it on both sides.
Lurp06x is offline
Old 01-15-2010, 06:19 PM
  #205
008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hear you ... we need a tire selection for this truck.
008 is offline
Old 01-15-2010, 07:50 PM
  #206
Lurp06x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes agree tire selection for the mini slash would be nice. i think that the main reason why this thread is so dead. at first when the mini slash came out it was all the rage, but since the merv an no hops or new bodies or tires have come out for the mini slash its kind of a downer an makes people want to find something else were they can continue to drive an build up there rc. but the mini slash so far is just a stock rc an thats all you can do for it except put Aluminum parts on an up grade the battery an charger.
Lurp06x is offline
Old 01-16-2010, 02:31 PM
  #207
Ttam Says Blarg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought that this truck would have way more support behind it.
Old 01-17-2010, 10:22 AM
  #208
combatman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone tried applying thin CA glue to the sidewall and part of the outer tread of the front tires to reduce traction roll? This is a trick used by carpet racers to avoid traction roll. So, the parts of the tires with CA will be hard and smooth, and the front end of the truck will "push" through the turns a little instead of grip the road, thereby preventing traction roll. How far along the outside edge you would need to apply CA glue, and not completely lose steering, requires some experimentation...
combatman is offline
Old 01-17-2010, 12:05 PM
  #209
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: combatman
Has anyone tried applying thin CA glue to the sidewall and part of the outer tread of the front tires to reduce traction roll? This is a trick used by carpet racers to avoid traction roll. So, the parts of the tires with CA will be hard and smooth, and the front end of the truck will ''push'' through the turns a little instead of grip the road, thereby preventing traction roll. How far along the outside edge you would need to apply CA glue, and not completely lose steering, requires some experimentation...
most CA glue will crack and flake off with rubber tires.. if your talking the stock tires
CAing foams on a short side wall will help for a race and also it can wick into the foam vs rubber for a better bond
this would help with foams on the mini
srt10 is offline
Old 01-17-2010, 12:41 PM
  #210
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just tape the tires instead. Cut a length of electrical tape long enough to go around the tire and have a little overlap, then lay it on a sheet of glass and slice it down the middle so it's 1/2 width. Then wrap the outer edges of the tires with this, seems to be just about the right balance so that you can slide without traction rolling, yet not turn it into a drifter.
BuzzBomber is offline
Old 01-17-2010, 02:35 PM
  #211
combatman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used CA on rubber tires before, and it lasted for a few weeks. I wonder if anyone tried either the CA or tape on the stock tires when racing their 1/16 Slash on carpet.
Old 01-18-2010, 03:19 PM
  #212
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: combatman
That's where I was running my slash with the taped tires last weekend. In between the heats, I was goofing off with that truck on the carpet oval track.
Old 01-18-2010, 11:20 PM
  #213
Gyronator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys just bought some down stops the other day and was wondering how to install them. Packet came with these http://www.horizonhobby.com/ProdInfo...SC6466-100.jpg 8 smaller/shorter ones clear ones. Dont know witch one goes in what order and how many to put in each shock.
Gyronator is offline
Old 01-19-2010, 12:58 PM
  #214
katzcratch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I changed the pinon on the slash for the series connector..now its raining of course
Why dont all compaines make their system like traxxas. that motor fits so nicely against the spur, and the boolt on the pinion is fat...and the motor shaft has a flat spot!!
I raced some skateboarders down a steep hill, it crushes them but I kept running into the curb...
katzcratch is offline
Old 01-19-2010, 10:59 PM
  #215
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
alright guys. i am definitely agreeing with you all here, in saying that the mini slash needs more wheel and tire options.
i just came back from testing a set of hpi 2.2" wheels with 6mm offset, paired with traxxas mini erevo tires. while this combo gets rid of the tires rubbing on the frame, due to the 6mm offset, mounting the wheel to the axle is not as secure. i bearly run out of axle thread when mounting these wheels, and i wish i could turn 2 more times to be absolutely secure. and, while it works for short burst runs and general bashing, the tire to wheel is not a perfect match, and can wobble after a while. as the wheels are failry exposed, they do get scuffed up pretty badly in short order. net net, i would not recommend this direction.
added a couple more tweak mods to my mini slash.
- turned the bent AM receiver antennae tube to face forward (this antennae setup works great, as it hides under the body, and still gets good radio reception.)
- added small nylon washers to keep the body from rattling so much
oh, and i have one more mod, well, this time, to the stock radio. i saw another basher here mount his camera to the radio using rubber bands. i thought, well, maybe my mini tripod might work here. and it does! i'm happy that it came out kind of nice and clean. the mini tripod, i think named "ultra pod", has this tree-hugging velcro strap feature already built in. i thought, "wow what an unimpressive feature" when i first bought this thing a few years ago. who would've thunk it will work so nicely here? for the most part, my wife helps me with my RC stuff only on my birthday (sob sob). so, this self-film feature might be fun to play with. we shall see.
keep bashing, guys.
-foam crazy
ID:	1359883   Click image for larger version
ID:	1359884   Click image for larger version
ID:	1359885   Click image for larger version
ID:	1359886   Click image for larger version
ID:	1359888   Click image for larger version
ID:	1359889   Click image for larger version
Foam Crazy is offline
Old 01-20-2010, 07:06 PM
  #216
Lurp06x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats a pretty sweet [X(]
for now i am going to wait on modding until stuff breaks, i thought about buying a bunch of tires and rims an seeing what works but i will wait on others to do that. but i have been doing some snow bank bashing and mastered the wall run on the side of a 6ft snow bank. wish i had a video camera to show . funny thing is i get some weird looks from people as they see a grown man playing with a mini slash. but all the kids in the neighborhood love to watch and i dont mind letting them drive it either because its fairly bashable. this mini slash keeps getting better each time i drive it. cant wait until summer to take it out to the track. well during the summer my wife has claimed it as her rc to drive while at the track.[:@]
Lurp06x is offline
Old 01-20-2010, 09:17 PM
  #217
HidosDeBrazil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Crazy, whats that on your radio?
HidosDeBrazil is offline
Old 01-20-2010, 11:32 PM
  #218
cul8tr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like a camera mount I think.
cul8tr is offline
Old 01-20-2010, 11:53 PM
  #219
Lurp06x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes it is i think thats what he said in his post
Lurp06x is offline
Old 01-21-2010, 09:45 PM
  #220
combatman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Foam Crazy
hello everyone,
this is i think my first post in the cars / trucks area. i'm normally a plane and heli guy. and so this is my first truck. my 1/16 slash is pretty much stock, other than a few mods here and there.
i am still looking for that perfect on-grass off-road wheel / tire combo. for now, i've settle on using the 1/16 e-revo wheel / tire combo as it does really well on the thick heavy grassy stuff. i'm very happy with what this combination can do in my front yard. i'm a beginner at bashing, and i don't really like to try to break this thing too much. after all, i've invested good money in this thing, so i like to take it fairly easy.
here is my mods list:
- stock 1/16 e-revo wheels and tires (let's me run on thick grass)
- trimmed body around the wheels to allow more clearance
- deans ultra connectors all the way around (an old habit. traxxas connectors look to also do the job just fine.)
- deans ultra parallel connector (i almost always run a single battery pack though)
- velcro wrap on speed controller wires to parallel connector to keep the wires from banging around (airplane / heli habit)
- ace hardware springs (no more sagging and bottoming out even under heavy acceleration and medium jumps)
- coiled antennae (stays inside the body shell which is good for when the truck flips. this is the stock AM radio system.)
- trimmed battery door (i've opened up the front of the battery door to allow the battery wires to run out the front.)
- 2s 2200mah lipo battery (i think these are the hobby-king zippy flight 25c packs)
- battery bay foam padding (keeps the battery from banging around inside the compartment)
- traxxas speed pinion
this setup is an absolute riot, and this thing is a wheelie machine. i can readily go even slight downhill, at about 10mph and still flick the trigger to bring up the front end. i do my share of sliding it on its roof and end-to-end cartwheels down the street. i'm very pleased at how well this thing holds up in tumbles.
keep having fun, guys!
- foam crazy
Hey Foam Crazy,
Can you provide any specifics on those Ace Hardware springs? Stock number, or anything else? Were they an exact fit, or did you have to trim them? Thanks!
Old 01-22-2010, 09:24 AM
  #221
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i believe they were #93 compression springs. best way is to take your shock with you to ace hardware and try it on. it was an exact fit with no mods. try the link below also for more info. i lurk both sites for info.
http://monster.traxxas.com/showthread.php?t=492114
Old 01-25-2010, 05:11 PM
  #222
Foam Crazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okay. i recently bought this painted castrol GTX body off of ebay. while i will probably never bash with this lid, it is an absolute joy to stare at, and worth every penny i paid. i wanted to show it to you guys. cheers.
ID:	1364419   Click image for larger version
ID:	1364420   Click image for larger version
ID:	1364421   Click image for larger version
ID:	1364422   Click image for larger version
Old 01-25-2010, 06:37 PM
  #223
HidosDeBrazil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking to get a less towering steering servo for my 1/16 slash. Is there a shorter one on the market?
Old 01-26-2010, 02:22 AM
  #224
Ttam Says Blarg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I broke my steering arm. Where do I go to replace it..??
Old 01-26-2010, 12:24 PM
  #225
Lurp06x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.amainhobbies.com/product_...eering-Arm-Set
GO HERE
otherwise if you have a lhs and if they carry traxxas products they should be able to get you any part you need for any traxxas rc.
Lurp06x is offline
Reply
Display Modes
