View Poll Results: A poll
Voters: 28. You may not vote on this poll
Traxxas vs Trinity 1/16 cars!
WI
OK some of you guy's may not be with me on this one but I still have to do something for us the consumers, Traxxas came out with a new product (1/16 Revo and Slash) both awesome truck ((( BUT ))) I have to say they are pricey very pricey almost $300 bucks for a 1/16 scale truck? everything on these couple of rc's is reduce at an lesser scale than the actual 1/8 and 1/10 scale Revo and Slash ( so that means you cannot compare it with the actual 1/8 and 1/10 scale brothers, way to different on all aspect). Some Traxxas vehicle with the VXL system cost about the same as the 1/16 scale VXL. OK my problem is? I don't want to pay that much for a 1/16 scale toy truck, Traxxas still is one of my favorite brand. But I have to say that Trinity have a way better option on 1/16 scale machine than the new 1/16 scale Traxxas, and it cost way less then the before mentioned, so what you guy's think of this?
Traxxas $289.99 for the all plastic 1/16
VS
Trinity $229.99 aluminum parts and adjustable suspension 1/16
all this at Towers price
SALE FOR $229.99
This is the electric powered, radio contrlled, ready to run
1/16 scale Trinity Now Brushless Powered Truggy.
FEATURES: Chassis: .079" (2mm) thick aluminum construction (silver in color)
Drive: Four wheel, shaft driven
Motor: Trinity 280 size brushless
Electronic Speed Control: Castle Creations Mamba 25 with Tamiya style
battery connector, bullet connectors and on/off switch
Radio: Pistol grip FM 27mhz with servo reverse, trims and steering
dual rates (charge jack equipped)
Battery: 11.1V 1350mAh 25C LiPo with Tamiya plug and mini balancing
plug (pack diamensions 4.1" x 1.32" x .87")
Battery Charger: Balancing capable 2 and 3 cell Li-Po/Li-ion AC only
Transmission: Equipped with metal gears
Pinion Gear: 15 tooth metal construction
Body: Prepainted and trimmed
Wheels: White nylon 5-spoke - 1.42" (36mm) wide x 2" (52mm) diameter
Wheel Hex Size: .33" (8.45mm)
Tires: Off-road tread design - 1.4" (37mm) wide x 2.88" (73mm) o.d.
Shocks: Oil-filled, nylon threaded body
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Caster/Toe-in: Non-adjustable
Steering: Bellcrank steering with adjustable rods
INCLUDES: Trinity Now Truggy with FM radio, 280 size brushless motor, LiPo
battery, charger, Castle Creations speed control, instruction
manual
REQUIRES: Eight AA batteries for transmitter and charging the included model
battery with the included charger
SPECS: Truggy-
Length: 10.5" (268mm)
Width: 8.25" (209mm)
Height: 4" (101mm)
Wheelbase: 7.75" (197mm)
Weight: Not Listed
Body-
Length: 10" (254mm)
Width: 4.5" (114mm)
Height: 3" (76mm)
$229.99
This is the 1/16 scale nitro powered, radio controlled, ready-to-run
Trinity Next Off-Road Truggy.
Trinity states in the manual they won't cover the engine under the
warranty if Trinity brand fuel is not used. This is incorrect,
Trinity will warrant the engine as long as high quality fuel is used.
FEATURES: Chassis: Aluminum 0.08" (2mm) thick
Drive: Four wheel shaft drive
Engine: .095 cu in (1.5cc) Draked edition with 2 needle slide valve
carburetor, pull starter, ABC cylinder and liner construction and
side exhaust
Exhaust: Tuned, round aluminum manifold, with composite tuned pipe
Fuel Tank: 1.75oz (52cc) with flip top lid for fast fuelings
Radio: 2-channel AM pistol grip on 27mhz (channels are provided at
random by Trinity, so we have no way to select specific channels)
Transmitter features trim and servo reverse on both channels and
charge jack for optional NiCd batteries
Servos: Two micro size servos and a standard size receiver powered by
4 AAA batteries (batteries and recevier housed in a nylon radio box)
Body: Factory painted truggy body with pre-applied decals and a rear
wing for increased traction
Brake: Disc
Shocks: Oil-filled, threaded, composite bodied coil over with black
aluminum shock towers
Tires: Truggy stle with universal tread pattern for dirt or asphalt
1.5" (38.88mm) wide, 2.9" (73.68mm) diameter
Wheels: 1.3" (34.54mm) wide, 2" (51mm) diameter
Suspension: Wide track with front and rear sway bars and aluminum
lower suspension arms, multiple shock mounting positions, front and
rear sway bars
Caster: 15°
Ackerman: Adjustable, Ackerman refers to the inside wheel turning
faster than the outside wheel during turns
INCLUDES: Pre-built and ready-to-run Next Truggy, 2-channel AM 27mhz pistol
grip radio, and instruction manual
REQUIRES: AAA Batteries: 4 to power the receiver and servos
AA Batteries: 8 to power the transmitter
Glow Starter
Fuel: 20% nitro car blend
Building and track equipment
SPECS: Length: 10.5" (266mm)
Width: 8" (203mm)
Height: 3.5" (89mm)
Wheelbase: 7.5" (190mm)
Tread: 6.5" (165mm)
Track: 8" (203mm)
BODY SPECS:
Width: 5.25" (133mm)
Height: 3" (76mm)
$289.99
This is the electric powered, radio controlled, ready to run
1/16 scale Traxxas E-Revo VXL Racing Monster Truck.
FEATURES: Chassis: Nylon composite construction 0.08" (2mm) thick bathtub type
Drive: Four wheel
Radio: Traxxas TQ 2-channel 27MHz AM with waterproof digital high-
torque steering servo, waterproof receiver box, transmitter does
not have charge jack
Electronic Speed Control: Traxxas VXL-3m waterproof, with high-
current connector, training mode, reverse and low voltage detection
for use with 2S and 3S LiPo packs
Motor: Traxxas Velineon 380 brushless motor with Neodymium magnets,
sintered rotor and high RPM ball bearings, 3.5mm gold plated bullet
connectors
Spur Gear: 45 tooth
Pinion Gear: 28 tooth 48 pitch, extra pinion gear included for 50+
MPH operation with extra battery (see below)
Battery: One Traxxas Power Cell 6-cell stick NiMH with high current
connector, dual battery capability (extra battery (TRAC2925) and
series adapter (TRAP3063) not included and must be purchased
separately), vehicle is also compatible with 2S and 3S LiPo packs
(not included) LiPo mode on ESC must be selected
Battery Charger: 110V wall type
Body: Painted and trimmed with applied decals
Bumper: Front, black chrome
Shocks: GTR oil filled
Suspension: Revo-spec rocker actuated long travel inboard type with
telescoping universal joint shafts
Transmission: Ball bearing equipped with adjustable slipper clutch
Differentials: Sealed silicone filled planetary gear type
Ball Bearings: Rubber sealed
Caster: Non-adjustable
Tires: Multi terrain, with foam inserts 1.8" (46mm) wide, 3.2"
(82mm) diameter
Wheels: Gemini 5-spoke with black chrome finish 1.5" (38mm) wide,
2" (51mm) diameter, standard size 12mm hex
Steering arm with spring loaded servo protection
INCLUDES: RTR Traxxas Slash VXL E-Revo Racing Monster Truck with 2-ch radio,
painted body, 6-cell battery, charger, extra pinion gear and
instruction manual
REQUIRES: AA Batteries: Eight for transmitter
SPECS: Vehicle-
Length: 12.9" (328mm)
Width: 9.4" (239mm)
Height: 4.6" (117mm)
Front and Rear Track: 9.4" (239mm) distance between outer edges of
wheels
Wheelbase: 7.9" (202mm)
Ground Clearance: 1.7" (43mm)
Body-
Length: 11.3" (288mm)
Width: 4.3" (110mm)
Height: 2.8" (71mm)
VS
SALE FOR $229.99
manual
SPECS: Truggy-
Height: 4" (101mm)
Weight: Not Listed
Body-
Length: 10" (254mm)
Width: 4.5" (114mm)
Height: 3" (76mm)
$229.99
side exhaust
Brake: Disc
rear sway bars
Caster: 15°
Glow Starter
Width: 8" (203mm)
Height: 3.5" (89mm)
Tread: 6.5" (165mm)
Track: 8" (203mm)
BODY SPECS:
Height: 3" (76mm)
$289.99
Drive: Four wheel
connectors
Spur Gear: 45 tooth
(82mm) diameter
instruction manual
SPECS: Vehicle-
Width: 9.4" (239mm)
wheels
Body-
Width: 4.3" (110mm)
Height: 2.8" (71mm)
WA
RE: Traxxas vs Trinity 1/16 cars!
WI
Read before you vote and wy did you get to choose the one you voted for?
Thanks for sharing your opinion.
I'm not yelling. [sm=thumbs_up.gif]
Which one will your LHS carry the parts for? And if the Traxxas Mini's are anything like their big brothers then there will be a ton of aftermarket parts for them. All of the LHS where I live don't carry parts for the Trinity cars but they all carry Traxxas parts. So for me spending alittle more on a Traxxas Mini is better then searching for parts for the Trinity Mini. Plus you pay for what you get with Traxxas you get a proven product with Trinity you never know what you will get. Just my .02..........................
WI
That's fast enough for my kid and if I want to go faster I'll just switch motors to an 380 brushless is cheaper than buying a 3S Lipo battery.
WI
Like I said before as long Tower Hobbies and A Main Hobbies carey the parts it's all right for me. It only takes 2 dah 3 days to get here.
WA
I chose Trinity, because my lhs has parts for them & it includes a charger along with a 11.1 volt Lipo.
Only thing I don't like about Trinity's car is the body
ORIGINAL: MMT GUNS
IL
I have a Trinity NOW and an E REVO VXL and the REVO is head and shoulders above the NOW .
The NOW needs a lot of upgrades too be reliable the REVO needs nothing but better batteries .
The NOW does corner better but the REVO has a better drive train , I had too spend another 220 on the NOW too get it the way I wanted .
WI
ORIGINAL: t9dragon
Don't you have any LHS near you? It is much nicer to walk into the LHS and get your parts instead of waiting 2-3 days hoping they don't get lost in the mail.
ORIGINAL: MMT GUNS
Like I said before as long Tower Hobbies and A Main Hobbies carry the parts it's all right for me. It only takes 2 dah 3 days to get here.
Either way my LHS carry's Trinity as well my comment is for those who LHS don't carry Trinity products, I have ordered many many parts from both Mail stores and never had a problem with them.
sorry but is to good to be truth Trinity have Traxxas on this one and many of us like these kined of deals.
WI
ORIGINAL: KRO
Are your sure of this? better drive train? the drive train on the NOW is all metal and the 1/16 Revo is all plastic, if it true maybe is cause of the torque and power that 1/16 NOW carrys on. With just a 6 cell pack wont do as much stress on the tranny on the all plastic 1/16 Revo.
do you have any video you want to share with us comparing side by side action video? thanks in advance.
I have never had a good experience with Trinity. Every one of their cars I've owned always seemed to require a ton of hop-ups to make them competitivelyviable, so I cose the Traxxas Revo. That being said, I agree that the NOW is fast, but so are the Traxxas cars. IMHO they are all being made to be nothing more than dragsters, and that does nothing for me. I am interested in off-road racing, so all the hype about 3S and 4S batteries holds no interest for me, but I do admit these things can be absolutely ballistic if you're simply interested in drag racing or speed runs.
CA
I voted for the Traxxas because it's not that much more of an expense.I havetheSlash 1/16th.I was attractedto it because it resembles a real SC Truck quite closely.After recieving my mini Slash I can say that it does seem quite durable.I do like those wheels on the Trin though. I wonder if they will fit :]
NY
I voted Mini Revo. I have heard many bad things about the differentials in the NOW from a friend's experience. Personally I would go with Mini Revo(should have it sometime this week)
AZ
I have seen that Mini e-revo at the nearby LHS, that guy drove it around the parking lot to show me. I have seen nothng in 1/16 or 1/18 that could compare to that ever.
