HS 65 servo saver for mini t
MD
does any 1 out there know where i can get a servo saver for a hs 65 mg that will fit on a losi mini t ? i chipped the main gear on the servo and i really want to get a servo saver before i rebuild it .
looked all over tower and horizon and even looked on the kimbrough and i only found 1 servo saver and it has no description at all any help at all would be great thanks
MD
RE: HS 65 servo saver for mini t
are ya sure ?? the saver i have for the hs55 is way to small to fit over the splines on the 65 and thanks for the help HJ
MT
Let us know what they say mrbonez. I have two HS65HB on the way and need to get a SS for them. I thought the hitec on for HS55 would work and I have one so I didnt think anything of it but if not then I to would like to know what one works..
MD
ORIGINAL: MTboy
MTboy you will see when you get your 65's the main gear with the splines is about 2 times the size of the hs 55's main gear .
you can also upgrade your hs65 HB to a MG you can get the metal gears for the hs 65 think there like $17.00 or so for the mg rebuild and just rebuild your hs65 hb with metal gears and you have a hs65 mg great servo tho makes a big difference over the hs 55
MT
That what the plan is if the HB dont hold up like I think it will. Hell I used an Eflight servo without a SS for 2 months before it stripped, so I figure the HB will work fine if I can get a SS..lol Actually I think the MG would work fine without a SS for me just couse I'm not hard on my trucks and 99% of the time only run on my track. I guess on time will tell..
MD
the hb is a good servo but mine only lasted about 5 minutes with out a s.s. i am kinda hard on rc's tho but the metal gear version lasted a good while months and pretty hard smashin and bashin so i would think with a servo saver they should last a long time. i think you will like the 65 it is fast and accurate i didnt realize how much i was spoiled untill i went back to a hs 55 and man it feels like stock LoL will let you know if i have any luck with hitec if you have any luck let me know
HS65 has 24 spline, try rc18 servo saver from associated #21049.
I don't know if it required any modification, but you should take a look on it.
ORIGINAL: Papa Jay
MD
awsome thanks guys . I don't mind a modification it to get it to work i just need it to save them $17.00 metal gears LoL
