I'm all set, now!!
PA
I'm all set, now!!
Had to show u guys what i got today.... I've got n alot of good thoughts from u guys. I was just ready to order the lipo's and charger that i needed
from net... mlh's were too $$$. But i think i lucked out .I went to the shop where I race at(about a hr. away) and They had exeactly what i wanted....What a dumb @$$%# I am.
2- 3cell 640mah Super tiger lipos/ $16.99
Trinity 2/3 cell charger/34.99
2- packs Deans con. / $3.oox2
And they give me a 10% dis.
79.00 bucks BABY!!!!!
I think i did ok.....
What do u think guys???? The lipos packs fit perfect.
I hope this helps someone else out too.
OOPS! and the RPM front bumper.
OK
RE: I'm all set, now!!
That and they're only 9.6 A continous current draw. Not to burst your bubble or anything but you could have done better by ordering you stuff from HC.
If I were you I'd get what money back I could.
PA
why do u say that? the 640mah? I ran my buddies 730mah 3cell and I was pretty happy with it. These seemed a better deal then to get cheap hong kong ones with 1000mah.
OK
Depending on what you're running it in...size and power output make a big difference.
And FYI, hobbycity sells some good ****. Let me go make a small package to demonstrate.
OK
[link=http://hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=9164]Better battery[/link] x2 = $16.58
[link=http://hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7028]Way better charger[/link] = $34.99
Add in registered air mail shipping = +$14.99
Total = $66.56
Total = $66.56
Yea, Hopefully you can get your money back.. 9.6amps isn't even near enough. Also thats just a lipo balancer not any good for anything above 750mah IMO.
OK
ORIGINAL: Wild YFZ 450
ORIGINAL: Snipin_Willy
No, it is a charger. It's just analog, non-adjustable, low output, charge cells individually type of charger. They can be bought for $5 on hobbycity, and the work really well for $5, I've used one on a 5000mah 3s battery.
OK
Long enough. The battery itself is being used to power a transceiver in my dad's airplane. The plane doesn't have a built in electrical system and all the avionics run off the pitot tubes. He wanted a battery to give his transceiver more use time before having to put it on the charger. Worked out well , he can just plug in the Lipo the day before or fly in the evening, which is what he usually does.
