installing hit 55 servo
Iam tryin to install the hit 55 servo into the mini t. Icant get the servo to sit right in the slot.. and the the mount pins dont line up..
anyone us this servo before? there is a conversion kit you have to put on first, and man the spring was hard to get clamped..
apparently this is the servo needed if you want to upgrade because the orig is a 4 wire.....
any thoughts would be cool
RE: installing hit 55 servo
ORIGINAL: katzcratch
take a file or hobby knife to the slots for the servomount pins, till you get it in a happy spot.
what "spring" are you talking about?
the servo saver spring? (yes, they have some tension to them) ~ you did get the hitec-servo specific servosaver, right?
MD
the hs55 will need a different servo saver from the stock losi servo like this 1 http://www.atomicmods.com/Products/T...55__12652.aspx
MD
I am tryin to install the hit 55 servo into the mini t. I cant get the servo to sit right in the slot.. and the the mount pins dont line up..
The conversion kit I was referring to was the two arms that fit together. the htect comes with a helicopter looking "x" on it.
The kit has a spring, a washer that snaps over the spring and keeps the two black arm pieces together.
The item in the link is the "kit" I installed
I just was not able to get the darn thing to fit into the mount. there was something about making the holes in the ears biggger?
has anyone cut the holding tray for the servo to make it longer.. then used the servosaver from the mini dt?
That one is just a little too long.
Y didnt they just make a 3 wire servo exactly the same as the the stock 4? What did they want people to do when they upgraded? they don teven have a part to fit.. this is really a bummer..and its raining!!
MD
it should fit i have alittle trouble getting them in there but they will fit. just leave the little screws loose that hold the black ears to the servo and angle the ears alittle bit and that should doit mine never fit right on the bottom i just make sure the top pins are in the holes in the servo hold down .
ok cool...did you have to move the holes that the black ears fit?
If not I guess you just tilted them in? There is only 1 screw to hold each ear on mine..I imagine that is the same.
Strange losi never made "good" fitting one with 3 wires...
thanks will try tonight..again
MD
i never moved the holes. but your right they do not fit the way you would think . was hoping you would get some better advice i usually forget something . anyway have fun with it and take your time
WEll if you got it to work, then it definitely is doable
I had hard time with that spring on the servo arm as well.. I am still new to this
ORIGINAL: mrbonez
Losi isn't in the "servo business" - whereas HiTec, and others, make higher quality aftermarket servos.
I use the HS55 Hitec servo in my Mini-T. The only thing I had to do differently is also change the servo saver. Everything else was a direct fit.
MD
ORIGINAL: MINI-RACER
All I have had to do is modify one of the holes in the chassis, just slot it a little. One screw on each ear should be OK. I also use servo take under mine to help secure it a little more solid.
Losi isn't in the ''servo business'' - whereas HiTec, and others, make higher quality aftermarket servos.
Strange losi never made ''good'' fitting one with 3 wires...
MD
ORIGINAL: studysession
It's because he is on moderated status. Because of his behavior on the site.
ORIGINAL: mrbonez
for some reason i couldn't see your post's
YEs!! I did get it in.. I hope I dont have to take it out! Thanks
I loosened the ears and just cheated it into place. had some trouble getting things to line up at neutral so I made the camber are longer? it seems to have worked.
I had only driven the dt before this... The desert seems to be smoother rider.. do yuo agree? I changed out the bushings on the mini t.
Are there better wheels? I guess I need the mip dif and the cvs's.. It seems there is allot of movement in the rear wheels. Dont know how to describe it but they dont seem to rotate as effencfietnly as the dt
Of course 10in after getting it running the pin gear popped off, then I couldnt set the motor to the correct tightness. It was messing way to tight..
I knew it didnt sound as "clean"
Another project but atleast the servo is funtctioning.. thanks..next time I will mod the chasis hole.
