1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Mini LST center diff questions.
Reply
Old 12-07-2009, 09:12 PM
slickcb2000
slickcb2000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mini LST center diff questions.
Well I got my Brushless mini lst in, within about 10 minutes I shredded the center diff. Has anyone used this and is it worth the money?
http://cgi.ebay.com/LOSI-LOSB1125-BA...item439b36f3ba
slickcb2000 is offline
Old 12-07-2009, 09:16 PM
cool-joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mini LST center diff questions.
Personally I would use the MIP balldiff instead of the Losi one.
Have you bothered reading any of the other MLSTthreads? They will help you get a better understanding of what you're dealing with.
cool-joe is offline
Old 12-07-2009, 10:00 PM
slickcb2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have looked for some back dated threads. Didnt find too much info. So i'm assuming this is a common problem with them?
Old 12-07-2009, 10:03 PM
slickcb2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 12-07-2009, 11:10 PM
cool-joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: slickcb2000
You might try again, there's lots of good info.
cool-joe is offline
Old 12-08-2009, 12:17 AM
Go-Zilla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have that losi one. Works ok. Make sure your slipper clutch is not too tight also, otherwise that little plastic bevel gear in between the center diff and the shaft gear is going to strip too.
MLST/MLST2/MMB... all have similar design with lots of drive tran problem. Once go BL, strips lots of gears on both front & rear, then center. Make sure you are not putting in too much power. Perhaps 1 in 50 owners you will find doesn't have any problem.
Go-Zilla is offline
Old 12-09-2009, 09:21 AM
slickcb2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well.... I went to my LHS and just got a set of factory replacement parts. The literally lasted about 10 seconds. I jb welded it after I stripped the spider gears out. Maybe since it's locked now it will hold for a little bit anyways. It's gonna be up for trade soon anyways.
Old 12-09-2009, 10:54 PM
Go-Zilla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, Welcome to the MLST owner club ! Where we spend endless hours and money trying to make the d-mn thing run without something broken inside.
Go-Zilla is offline
Old 12-10-2009, 10:27 AM
cool-joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since the truck was never designed, nor intended, to be able to handle brushless power if you motor back, and treat them nicely, and use them as they are intended. They tend not to have nearly as many problems relative to keeping them up and running.
If you want race-worthy-speed truck, buy a race-worthy-rig.
cool-joe is offline
Old 12-10-2009, 09:40 PM
etc1006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got one in a trade. I was pleasantly suprised when I did a tear down to clean/inspect that it had the steel diffs front and rear, and a ball diff in the center. Now for a decent slipper for it.
etc1006 is offline
Old 12-11-2009, 07:35 AM
Go-Zilla
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: etc1006
MLST has a plastic diff. MLST2, Limited (MMB), these have the metal diff rings & metal pinion gear. But the 4 spider gears inside the diff are plastic thou. That's the only setback.
Go-Zilla is offline
Reply
Display Modes
