Micro Raminator
Moderator
RE: Micro Raminator
CA
RE: Micro Raminator
Another option is to buy the Micro High Roller and then get the Losi threaded axles for the Micro T, the Micro Raminator body and Micro Raminator wheels/tires (all are currently available on Ebay). Use a little ingenuity to mount the MR body on the MHR. I drilled a hole right in the center of the two front holes on the MR body in order to use the MHR front body post. I then used velcro to hold the sides of the body to the sides of the chassis. You will need to drill another hole for the antennae to go through (right in the center where the rear of the cab meets the truck bed).
