ESC with LVC?
ESC with LVC?
can you guys point me to a brushed. micro speed control with low-voltage cutoff?
i just got a couple of mini-t's(rollers) and want to use my 2s lipos. are there any that cost around $20?
FL
RE: ESC with LVC?
Not that I know of. There is a 10th scale brushed ESC with lipo cutoff, but it would be a tough fit for a mini-t. You will likely have to go with a brushless ESC that also runs brushed motors, like the Mamba or Sidewinder.
MI
RE: ESC with LVC?
ORIGINAL: mrgoodbar
funny
ORIGINAL: nitrosportsandrunner
http://hobbycity.com/hobbyking/store...0A_BRUSHED_ESC
Turnigy is a good brand as well. This does not exactly have LVC, it slows you down significantly at 3v to let you know. Either way, you should not be running your batteries to lvc level, it is very bad for them.
My Feedback: (26)
RE: ESC with LVC?
ORIGINAL: john2364
Really not funny at all. Here you go
ORIGINAL: mrgoodbar
funny
I'm not sure if the mini t has enough room, but the brushed esc that comes on the SC10 has a lipo cutoff. You can pick those up off ebay for about $20.
Hope this helps.
RE: ESC with LVC?
could he just add a lvc to the esc like the one from novak for 24.99
http://www3.towerhobbies.com/cgi-bin...&I=LXPGM8&P=ML
