duratrax mount for castle
HAs anyone found an easy way to mount a castle motor to a duratrax car? The motor mount does come close to set holes.. I was going to drill new ones but wanted to see if someone had used another part?
thanks
thanks
FL
RE: duratrax mount for castle
I have to assume you are asking about the Vendetta, and the standard 20mm Castle motors. I have never had a problem getting mine to fit, maybe just elongate the holes a tiny bit but thats about it. The real problem is that any of the Castle motors will overheat rather quickly in any of the Vendetta series cars and trucks, they are just not meant for that heavy of a car. You can likely make it work, but you would be better off with at least a 24mm motor.
