Would you have to do other upgrades to run this set up
in a 1/16 vxl Revo?
http://www.maxamps.com/proddetail.ph...11&cat=220 |
RE: Would you have to do other upgrades to run this set up
you would need a new ESC lol
Thanks.
ORIGINAL: moezer you would need a new ESC lol they come with a PARALLEL connector so it would just double the run time. Now if they are hooked up in series they would make the ESC, and motor go POOF real fast. I ran 2 2s lipos in parallel on mine when I used it fine. |
Okay.When you ran the lipos did it have more power also,or just still longer run time? That's what confuses me with all the different batteries.I'm new to electric besides the old OLD tamiya Hornet in the 80's.Now i'm lost.
oops sorry i thought it was the series coinnection lol, yes u would get power and more run time, changing to lipo is wayyy better, and yes it will be hell of alot faster.
Nimh batts are heavy lipo depending on its size in cells are much lighter then your normal NIMH batts,6 cell NIMH batts are 7.2V while the 2Cell lipo is 7.4, but when u charge them they go up to 8.4 fully charged. Also watch out for the burst ratings, the more burst rating u have on a lipo the faster the Voltage is going to pass through the truck to power it. Also remember this with higher burst your esc and motor will heat up much faster, if ur new to lipos stay ar 2s lipos at 20 to 25 C burst rating. Make sure you switch your ESC to lipo mode, unlike normal NIMH batts if a lipo drops below 3.2 vots depending on the lipo then u may ruine your lipo and wont be able to charge it. So when u switch the ESC to lipo mode the ESC will know when to warn you to stop playing with the RC. Unlike NIMH batts u can drive them tell the batt is dead and then recharge. Its not the case with lipos. Another thing is, always and i mean always make sure you charge the LIPO on its rated C rating or below, so for example you have a 2000 mah lipo u can only charge it at 2 amps or below, never charge it over 2 amps or ull risk damage to the lipo batt or worse is it blowing up and setting fire to something. Always read what the lipo batt says on it and all its warrnings, some lipos can be 2000 MAH and u can charge them at more Ampage. Just read what is the max charge rate should be and what is the max discharge u can play tell u need to stop |
as for power no (I'm guessing you mean oomph)
2 lipos will give the same power as one unless the single one is severely underrated they should just give longer run time in the merv running in parallel the extra weight helps keep the thing planted more though so it does have a bonus over longer run times |
ORIGINAL: SyCo_VeNoM as for power no (I'm guessing you mean oomph) 2 lipos will give the same power as one unless the single one is severely underrated they should just give longer run time in the merv running in parallel the extra weight helps keep the thing planted more though so it does have a bonus over longer run times Im not sure if you noticed that those set up from the AD are 3S lipos not 2, can you put 3S lipos in Parallel? I always read and was told not to put a 3s lipo in Parallel in my summit and i think it says that in the manual or something doesnt it? 3s in a revo is going to be too much for you to handle, if your new to lipo and dont know there limits any ways good luck nitroholic This what it says in the traxxas manual about lipos. <p align="left"></p> <font size="1">LiPo Batteries </font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad"> Lithium Polymer (LiPo) batteries are becoming popular for use in R/C models due to their compact size, high energy density, and high-current output. However, these types of batteries require special care and handling procedures for long life and safe operation.</p></font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">Warning: </font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">LiPo batteries are intended only for advanced users that are educated on the risks associated with LiPo battery use. </font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">Traxxas does not recommend that anyone under the age of 16 use or handle LiPo battery packs without the supervision of a knowledgeable and responsible adult. </font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad"> The VXL-3m electronic speed control is able to use LiPo batteries with nominal voltage not to exceed 11.1 volts (3S packs). LiPo batteries have a minimum safe discharge voltage threshold that should not be exceeded. The Velineon VXL-3m electronic speed control is equipped with built-in Low-Voltage Detection that alerts the driver when LiPo batteries have reached their minimum voltage (discharge) threshold.</p></font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">It is the driver’s responsibility to stop immediately to prevent the battery pack from being discharged below its safe minimum threshold. </font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad"> Low-Voltage Detection on the speed control is just one part of a comprehensive plan for safe LiPo battery use.</p></font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">It is critical for you, the user, to follow all other instructions supplied by the battery manufacturer and the charger manufacturer for proper charging, use, and storage of LiPo batteries. </font></font><font size="1" face="Myriad,Myriad"><font size="1" face="Myriad,Myriad">Make sure you understand how to use your LiPo batteries. Be aware that Traxxas shall not be liable for any special, indirect, incidental, or consequential damages arising out of the installation and/or use of LiPo batteries in Traxxas products </font></font></p> |
Extremely helpful information with lipos and the other batteries.Thank you.
Thank you guy's so much very helpful.I appreciate that.
ORIGINAL: nitroholic Thank you guy's so much very helpful.I appreciate that. |
For sure cause like i wrote i'm clueless with electrichttp://www.rcuniverse.com/forum/js/f.../omg_smile.gif
why cant you run 3s in parallel in a Merv?...... Only thing I could think of logically would be heat issue from extended run times?
ORIGINAL: trickle007 why cant you run 3s in parallel in a Merv?...... Only thing I could think of logically would be heat issue from extended run times? |
