RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   1/16th, 1/18th, Mini & Micro RC Cars (http://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/)
-   -   spur gear issues (http://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/11315120-spur-gear-issues.html)
whipmastajr 11-30-2012 03:15 PM
spur gear issues
<span style="font-family: Verdana, Arial; background-color: rgb(251, 252, 255);"></span><span style="color: rgb(74, 74, 74); font-family: arial, verdana, geneva, lucida, 'lucida grande', helvetica, sans-serif;">I have 1/18th scale dirt modified body changed over from the late model body and the dual disk slipper clutch ! I need another spur gear for it and all that is available is 60 tooth LOSB 1137 ! Can't seem to find any higher or lower spur gears ! Can you get them in metal? Also run on banked dirt oval in the summer about 50 ft track, what pinion and spur would you recommend for a 5400 kv motor ?What pitch goes with the spur gear LOSB 1137 and pinion as well ? Also we race on flat cement with the Late model converted back with the same chasis in the winter ! What pinion and spur do you recommend for a 16 to 18ft track area 10 ft wide?</span><span style="font-family: Verdana, Arial; background-color: rgb(251, 252, 255);"></span>
