street racing
can da mini z be modified to rece on da streets or on smooth aspalt or sumting....?
RE: street racing
I've driven my Overland Mini-Z in the dirt and on asphalt without any problems. The F1 would probably be a different story since there is very, very little ground clearance.
RE: street racing
As look as its smooth, you should be able to. I use to run mine in front of radio shack, when I worked there. The only thing I have to say is as long as its smooth. Or if there are holes then use them as turning points. Just have fun.
Tony |
