Mini LST
I am looking to get a mini lst. But I want to make sure that other 1/18 scale motors will work with the stock esc. Will two of these http://www2.towerhobbies.com/cgi-bin...&I=LXJJG3&P=ML work with out the esc failing? Are there any other esc that can work with two motors? And what pinion/spur should I start with? And please suggest any motors that would work better. I do not want to go brushless. Thanks for any help.
RE: Mini LST
They would work, but those arent exactly the best choices for a mini lst. You really want two micro mods such as the URC Krystal or Beast Raptor, or Trinity Cobalt. Dual Krystals work fine with the stock ESC.
RE: Mini LST
OK, I looked for the motors you suggested but all I could find was this one http://www2.towerhobbies.com/cgi-bin...&I=LXLPV1&P=RF . Will two of these work with the stock esc? Were could I find the URC Krystal motors, I couldn't find them. Which would you think is the best at speed and acceleration.
RE: Mini LST
17t is the lowest I know of that the ESC can handle.
The Krystal can be found at www.unitedrc.com The Raptor can be found in the one18th shop at www.one18th.com |
RE: Mini LST
I have a few more questions. Why would the mini max motors I suggested first not be that good of a choice? And dose Trinity Cobalt motors come in 17 turn, I only found 16 turn and that wouldn't work, right?
RE: Mini LST
The motors you posted wouldnt please you, you would be better off buying the Insanes then those. I went brushless, and its cost me less then a nice brushed system so Im happy.
RE: Mini LST
brushless shop: http://www.b-p-p.com/products.php?ca...9b0962ce3127f9
RE: Mini LST
OK, I think I am going with the Trinity Cobalt 16 turn motors or I am going brushless. What ESC should I get to use dual Cobalts? Thanks for the help.
RE: Mini LST
To use dual cobalts you will have to get a no limit ESC such as one by Novak. That paired with the motors and your spending over $50 more then brushless.
RE: Mini LST
novak micro gt esc: http://h1071118.hobbyshopnow.com/pro...p?prod=NOV1875
RE: Mini LST
Well that settles that, when I get my mini lst I am going brushless. This is what I have in mind http://www2.towerhobbies.com/cgi-bin...&I=LXHAH9&P=RF . What pinion/spur should I get? Will this fit right in, what else would I need? Is there a different system you would suggest?
RE: Mini LST
I would NEVER run a mamba in the MLST, go to www.b-p-p.com and find a motor you like besides mamba. You want 370 or 380 size.
RE: Mini LST
OK I'll look, what do you run?
RE: Mini LST
ESC: Quark 33a Pro-Car
Motor: Some 7200KV motor I bought off ebay for $1, ill probably replace it with the Wraith, but Im waiting to try it with a better battery. |
RE: Mini LST
they say that the wraith is the best one out now, guy i have on msn says that he got his mlst to 70 kilometers per hour with one of those wraith 7k's
RE: Mini LST
The wraiths are nice, but Im waiting on some information over a problem for the MLST.
RE: Mini LST
Wow there is alot of misinformation in this thread.
You can run 2 cobalts off the stock esc. Running 2 of the 14t motors will cause thermal shutdown so if you wanted to run the 14t's I'd suggest a better esc however it doesn't have to be a no limit esc. Any cheap 1/10 scale esc will do. Let me tell you there isn't much difference between running one cobalt or two. That's why I run a single 14t cobalt. $40 bucks for the motor & on the track it would hang with any bl setup you could throw at it. |
RE: Mini LST
I thought any 1/10 ESC would work, but then I saw people running no limit ESC's with their cobalts so I figured you needed a no limit.
RE: Mini LST
Any 1/10 esc will work...its all in how you wire them up. The # turns on these 300 size motors is not comparable to 540 cans. The stock esc is heck of alot better then a spy.
RE: Mini LST
the stock esc of the mlst better than the spy!??
RE: Mini LST
on my stock esc i have improved the contact between the heatsink and the fets that its supposed to be cooling... hotter heatsink, cooler fets... maybe this will mean that my esc is slightly better than stock now
RE: Mini LST
Hey Inverted why would you not run a mamba system? I've heard them to be good.
RE: Mini LST
The mamba is made to replace size 300 motor applications. Many users have burnt up their motor as the truck's size puts too much load on it. Stick with a 370/380 size motor. Anything from B-P-P, other then a mamba would work well.
RE: Mini LST
OK, that makes sense. With these brushless motors do you have problems with the diffs wearing/striping?
RE: Mini LST
or u can run a duel mamba.
i reccomend the wrath with the quark i heard people have problems with diffs |
