Radio / Servo / Batt Question
What's a lightweight radio (4ch), servo and battery (lithium ?) recommendation for a .010/.020 plane to work with my Futaba 72 MHz transmitter?
slow-Poke-19
slow-Poke-19
I'm going to assume it's an FM transmitter.
Here's what I'd use:
Either a Hitec Electron 6 RX
or Hitec 555 RX
Hitec HS55 Servos
You need a 4.8v battery pack so you wont be able to use Lithium which is only in multiples of 3.6v.
Radical RC has 2 NiMH packs that would be suitable. Either the RRC-120 4.8V or the Radical RC 300mah 4 Cell 4.8 V pack should do fine.
or Hitec 555 RX
Hitec HS55 Servos
