Tile print
Does anyone here know where the PDF file button is in tile print?
RE: Tile print
Look on the toolbar along the top. It is a little to the left of center and next to the "minus" button on the zoom tool. Personally, I haven't had much luck getting it to work with pdf files.
RE: Tile print
Isn't there anything that does work for *.PDF files?
RE: Tile print
ORIGINAL: ChicaWolverina Isn't there anything that does work for *.PDF files? Yes, the latest version of the (free) Adobie Reader allows you to do this. Leastways I did it a few nights ago on my other computer. Give it a try. Ray |
RE: Tile print
I just downloaded Adobe Reader X and I still do not see any PDF button on the tool bar. I also have tried to contact Black Flight to no avail.
RE: Tile print
1 Attachment(s)
ORIGINAL: Walther I just downloaded Adobe Reader X and I still do not see any PDF button on the tool bar. I also have tried to contact Black Flight to no avail. You then go to the Page Handling button in the print window that's displayed and the select the "Page Scaling" option of "Tile all pages". Also select your scale of (say) 100%. See below and good luck. Ray |
RE: Tile print
I have adobe I guess version 7. something and under page scaling it does not give me the option to tile all pages. When I go online to try and download a newer version of adboe it locks up my computer. Does that happen to anyone else. I would like to get my adobe to tile print but I havent had much luck yet.
RE: Tile print
I went down to another computer and tried loading adobe 10 on it and it worked just fine. I was able to get my plans printed in tile format like I wanted. I dont know what is going on with my other computer because it just locks up when I try to download the newest verssion of Adobe off the internet.
RE: Tile print
ORIGINAL: locktite401 ORIGINAL: Walther I just downloaded Adobe Reader X and I still do not see any PDF button on the tool bar. I also have tried to contact Black Flight to no avail. You then go to the Page Handling button in the print window that's displayed and the select the ''Page Scaling'' option of ''Tile all pages''. Also select your scale of (say) 100%. See below and good luck. Ray Thanks for your help. |
RE: Tile print
You might try to uninstall the old version and then reload new version.
RE: Tile print
ORIGINAL: unclecrash You might try to uninstall the old version and then reload new version. |
RE: Tile print
I got a hold of Andrew at Black Flight, and I removed the program reinstalled it and now I have the PDF button. But I still can not use it. Andrew told me to open the file, scale it to 100% then take a snapshot of it, select all, copy, then paste it into Tile print. That works so you do not need the PDF button.
RE: Tile print
Walther;
If you are having difficulties installing Adobe X, it may be due to the minimum requirements being XP SP3. I have found that many software vendors now look at the version of Windows and will not install their software without SP3 installed. Office 2010 from Microsoft is one of those for example. Check your system specs. Adobe may just be impolite and crash when the minimum is not met, but fails to indicate why. Also, it needs 230mb to install. If you have an older machine running tight on disk space it could also cause issues. Adobe X seems to be a resource hog once installed. I reverted back to 9.4 myself. Jim H |
RE: Tile print
I did not have a problem loading Adobe X the problem is that Tile Print does not like Adobe X.
