PLANS
RE: PLANS
RCM&E, Traplet.com etc have lots of plans. Here is another one with kits that are just the right size for glow; http://www.warbirdkits.com/kits.html
Funny with the Guillows templates, they are certainly hard enough to last for a few builds....
MA
RE: PLANS
I am seeking trainer type plans in the Kadet style or possibly low-wing trainer types with 36" wingspans or smaller. Preferably stick-build and can be set up as either glow or electric. And I prefer to purchase them instead of downloads.
RE: PLANS
Although you have indicated that you would rather purchase plans, there is a sticky thread at the top of this forum called "Building and flying the LST trainer". It's an excellent flying plane, may be nitro or lekkie, and is a Kadet style highwinger. Plans are downloadable.
andrew
andrew
MA
RE: PLANS
Thank you for that info. The only reason I would like to purchase the plans is because I only have a simple 8 1/2x11 printer and because it dont print big sheets it is difficult to print out different portions of a plan and accurately paste them together for the correct dimensions.
I will check out that LST trainer
RE: PLANS
ORIGINAL: shd3920
http://www.donatelli.net/lst-half-a-trainer.pdf
MN
RE: PLANS
Here's a bunch:
http://www.airagestore.com/catalogse...lt/?q=randolph
Dave
Here is a link to the Flying Models Plans Catalog:
http://flying-models.com/catalog/catalog_rc.php
Or:
http://carstensbookstore.com/caflmopldi.html
and search on "Texaco" or "1/2a"
And some plans from my site, all good 1/2a easy flyers
and designed to print on letter size sheets:
http://my.pclink.com/~dfritzke/jrfalcongrock.pdf
http://my.pclink.com/~dfritzke/papillon.pdf
http://my.pclink.com/~dfritzke/Lil Tri Squire.pdf
http://my.pclink.com/~dfritzke/Lil Esquire.pdf
http://my.pclink.com/~dfritzke/Minnie Mambo-GeneRock.pdf
(I can see the spaces in the file names mess things up, so copy/paste into address bar...)
Home page may be easier, links to all:
Dave
Or:
RE: PLANS
I think 36 inches is really the lower limit for a 1/2A trainer using glow or diesel; my 1/2A trainer years ago had a 39 inch span, 290 square inches, and was just tame enough to learn on with a throttled Cox 049 and the mini radio gear of the time.
I second the Nickle, from AMA, by Randy Randolph. It would be my very first choice for a simple, attractive, and docile scratch-built 1/2A trainer. But I'm sure it's bigger than 36 inches...maybe 44 inches.
The old "1/2A Texaco" old timer designs are perfect for trainers. They were all stick built, but they typically run around 43 to 48 inch spans. Flying Models sells tons of them. AMA has the Kloud King reduced to 43 inches that would be very nice. They all came out around 16 ounces. With modern micro gear, a little less.
MAN sells plans for the "Kadetito" (or something like that) which is a mini Kadet, stick construction, right at the size you want. With micro radio gear you could make it a nice trainer with a TT 07.
Of course, with electrics you can go much smaller.
Jim
Jim
MO
RE: PLANS
Hi,
As a flyer and often instructer I would go for the LST Trainer. I really like the old timers myself but would hate to bang something that nice around while training.
A Mini Mambo might be nice compromize.
My Feedback: (89)
RE: PLANS
Hello,
Send me a PM with your e-Mail address and I will send you my 9 page listing of Plans for SCHOOLYARD Scale .049 or electric, Plus Several Scale R/C Plans for 1/8 Scale to 42% Scale, Sailplane Plans and a few Scale Rubber Power Plans.
Regards,
Ken AMA 1528
Regards,
Ken AMA 1528
RE: PLANS
yall all have great knowledge of where to get plans. does anyone know where to get kits? im just starting on my own without my old man. but have been doing this for 10 years so i wanna kit trainer 1/2a. something with say a 40inch wingspan.
