"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
.061 on a 2X4
Reply
Old 04-20-2011, 01:57 PM
skyraider71
skyraider71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .061 on a 2X4
I have just about got my H.O.B 2X4 framed up. My plan was to power it with a 400 size
outrunner. My hobby budget has tightened, and now I'm considering using a Novel .061
that I already have. The mount fits perfectly with room for the pushrod tube.
How will this combo perform?
skyraider71 is offline
Old 04-20-2011, 02:23 PM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: .061 on a 2X4
Should be fine. I remember guys using a Cox .049 engine on 72 inch wing span gliders before.
I once had a Xmas present given to me of a Cox RTF foamie glider with a 57 inch or thereabouts wingspan and it had a plain vanilla .049 reed valve engine and it worked just fine.
earlwb is offline
Old 04-20-2011, 02:24 PM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you'll find it quite satisfactory.
One of our club members flys a Goldberg Gentle Lady (~ 78" span) using a COX .049 on a powerpod. His plane is a little heavy and the .049 hauls it up, albeit not at a high rate of climb. The 2x4 is smaller and should come out lighter, although the wing loading may be a bit higher. The NORVEL has more power than the COX so you should get a nice climb out. The 2x4 can come out tail heavy and I would be inclined to finish covering it before mounting the servos - that will give you a better chance to balance it without adding any lead. I would also leave off the throttle servo and just wire the throttle open - you won't be doing any touch & go's anyway. You should expect around 7 to 9 minutes on an ounce of fuel, enough to get to altitude and putz around some before gliding.
andrew
Andrew is offline
Old 04-21-2011, 11:01 AM
BMatthews
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the engine proped for max power the 2x4 at full throttle will behave like a scalded cat! Fast steep climbs will be easy. Rudder rolls at speed will be sharp and snappy. Go easy on using lots of elevator at high speeds because you could easily generate enough G to bend or maybe bust the wings if you snap in full up from a fast power dive.
In fact at speed the typical settings for rudder and elevator throws will produce a very touchy to fly model. I'd suggest you use the dual rate option for aileron (used for rudder in this case) and elevator to set up for half throws for the power portion and then flick them to full rate for the glide after the engine cuts out or once you know that you can safely control it with full throws at higher speeds by just breathing on the sticks.
In any event it will NOT be boring to fly...
BMatthews is offline
Old 04-21-2011, 02:33 PM
mgnostic
mgnostic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A product .049 pulled my gentle lady around just fine with landing gear no less. I never got a successful ROG as it tended to run off the side of the runway before it had rudder authority (no tail wheel) but it flew nicely with a firewall on the nose and a 1oz tank.
mgnostic is offline
Old 04-22-2011, 02:07 AM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mmmm, I do also have a Norvel .049 C/L. Sounds like it could be a viable option.
Old 04-22-2011, 03:52 AM
eroc144
eroc144's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a 2x4 which is essentially a practice plane for my son. I put landing gear on it and didn't worry about using light batteries, servos etc and it ended up at 24 oz.
I've powered it with NV .049's, .061s, a dieselized .061, and currently an Enya .09. They've all flown the snot out of it. It can get twitchy at higher speeds, but then that isn't really what this plane is about anyway.
EG
eroc144 is offline
Old 04-22-2011, 04:24 AM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi EG -
Nice to see you around - you've been scarce lately.
andrew
Andrew is offline
Old 04-22-2011, 02:26 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Picked up a Hayes 2 oz tank that's a perfect fit. It's narrow enough to allow a pushrod tube on one side.
The gears in my head are turning.
Old 04-23-2011, 05:11 AM
eroc144
eroc144's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andrew. It's been a busy year!
EG
eroc144 is offline
Old 04-25-2011, 03:14 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Perfect fit. A 2 oz. Hayes tank also fits nicely.
ID:	1599072   Click image for larger version
Old 04-25-2011, 04:05 PM
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had a couple of Gentle ladies with .049 TD engines. I could do consecutive loops all day long. Great set up. In fact, the prop I liked most is the APC 6-2. I have contemplated getting another one as I just loved that set up. I ended up folding the wing at a polyhedral joint at very high altitude. I must have dived it too hard, and did not have enough strength at that joint. I was able to fly it without the outer panel for a little bit, but then the whole wing came off and the fuse became a 700' lawn dart. Needless to say, not much was left except for that 3/4 of a wing!
vertical grimmace is offline
Old 09-01-2011, 04:28 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought I'd share the build.
The kit comes in a small slim box, and has full color instructions.
ID:	1656292   Click image for larger version
Old 09-01-2011, 04:36 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuse sides are glued together. Then the former and nyrod locations are marked.
I will placing both servos in the same compartment since I will be using micros.
ID:	1656294   Click image for larger version
Old 09-01-2011, 05:50 PM
danilo-2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmm... Had a 2x4 from HOB. Truly it was the Crappiest Glider I've built and flown.
Heavy, crudely designed and clumsy in flight.
As advise ( unsolicited or not :-) I would 'definitely Discard the Light ply Fuse bits entirely and duplicate the parts in "normal' Balsa.
Result would be Lighter and far less likely to be Banana shaped.
Also suggest Making a dihedral break at the wing centre .
The OEM upturned wingtips/dihedral, while a bit easier to build are marginal in turns.
IFambitious, I also would give seriouis thought to either reprofiling the wing ribs or making entirely New ones in a 'better' Airfoil.
Gawd knows, most any 'moderne' airfoil would be a significant improvement.
Bitter? Yup... still, 25 + years later :-)
danilo-2 is offline
Old 09-02-2011, 02:38 AM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: danilo-2
As advise ( unsolicited or not :-) I would 'definitely Discard the Light ply Fuse bits entirely and duplicate the parts in ''normal' Balsa.
IF ambitious, I also would give seriouis thought to either reprofiling the wing ribs or making entirely New ones in a 'better' Airfoil.
My intentions for this plane are to utilize it as a trainer. I'm going to use it to teach my nine year old and maybe others.
Old 09-02-2011, 02:43 AM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The former are prepared, then are squared up and glued to one fuse side.
ID:	1656407   Click image for larger version
Old 09-02-2011, 02:48 AM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The other fuse side is lined up, and rubber bands are used to hold everything together for gluing.
Old 09-04-2011, 04:50 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Balsa rear fuse top goes on next.
ID:	1657693   Click image for larger version
Old 09-04-2011, 05:11 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didn't have the power system and radio worked out yet so I started on the wing.
The center section is built first with familiar techniques, nothing complicated here.
ID:	1657782   Click image for larger version
