Cox Tee Dee starter spring?
Looking for one of these spring for a Tee Dee 051.
Any idea if a Norvel 061 starter spring fits a Tee Dee 051? Are these better to use than a 1/2A electric starter?
Florin
Florin
My Feedback: (30)
TN
RE: Cox Tee Dee starter spring?
Try an ebay search; the current owner of the cox productions is a seller called xenalook, they have everything. The .049 spring should fit, but an electric starter is easier.
http://stores.ebay.com/XENALOOK
The Norvel springs fit well and one can make a little hole in engine mount instead of the mounting lug (like the Norvels have). I've never owned any electric starter, there is no need for them when if you have the spring starter, and larger engines are easy to hand flip.
My Feedback: (10)
BC, CANADA
TD 049/051 springs have been designed and sent for quote to a spring company.
We should have them available in aprx. 4-6 weeks for presumably $2.95.
Bernie
www.coxinternational.ca
Bernie
No need for a spring starter on a TD. To start a TD, you need a good hot battery. I use a 2 volt with a long cord. Choke it a couple of times with the needle open about three turns. Then squirt fuel on the side of the piston in the exhaust port. Hook up the battery. Turn the prop backwards to vertical. Hit the prop forward with your gloved finger, and adjust the needle to suit. With a little practice this will work every time.
ORIGINAL: SunnyFlyer09
I read that a spring starter causes a loss of power/rpm's..true?
