3-Blade Spinners
PA
RE: 3-Blade Spinners
I had seen them back in the day, I have one that came with my wenmac 049, but I havn`t seen any in years. I have been watching on ebay and havn`t seen any there either.
TX
Sad to say that I have never found a suitable three blade
spinner. My solution is to cut a regular spinner off at the
cutouts and hope no one notices. Someone with more
resources may have a better way.
ralph
ralph
I have 3 yellow, plastic, 3 bladed spinners sitting in front of me now.
Diameter is about 1 1/8 inches. I may be wrong but I think they were designed to clip onto the spinner adapter that also held the soft, red, rubber Cox spinners from the PT19.
Any use to you? - John.
Having a closer look at these spinners they have a ridge on the OUTSIDE of the tube moulded as part of their centre.
Do they clip into the black, 3 bladed props? I no longer have the props but I seem to remember a strange hub molded on the props which was similar to the spinner adapter in my last post. - John.
Probably one of those battles between Cox and Testors where they made everything non-interchangable...lol.
I just have a Cox grey three-blade prop that I might like on one of my planes which would look more to scale with a spinner.
I might just have to go generic with the Dubro aluminum spinner that all fits ahead of the prop but I dont like its weight.
Maybe I'll hunt out one of those cox stucka spinners. I dont even know if I'll stay with the prop or not..
Thanks John [sm=thumbup.gif]
John,
I have a couple 3 blade/spinners and props, but I think they are for pusher applications on Cox planes - not for sure, but can check if you are interested.
Dale
Dale
LA
If you need a custom spinner and have a small lathe then you might consider making one from scratch. The attached sketch shows one that is dimensioned for an .010 Cox grey prop. It is basically just a fancy prop nut with a balsa shell that has its skirt cutout for the prop blades. Give the balsa a coat of thin epoxy before final sanding and it ends up a lot tougher than you might think. Mine stands up well to the rigors of an electric starter. I haven’t used one on an .049 (I’m a wee engine guy) but I’m reasonably sure it would be plenty strong in that size as well. It isn’t nearly as fragile as it might seem at first glance.
Al
Al
I did a Google image search & I think the 3 spinners I have ARE Cox Stuka spinners.
Let me know if you have no luck finding them, you can have these for the cost of postage from Oz. - John.
