If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2007
    Loveland, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    051 Tee Dee Cloning to a .050 Tee Dee R/C
    Background: I’m trying to turn (clone) a .051 TD into a .050 RC
    using a new carb. from Bernie. The carb. seems to work fine but I can’t get it to
    idle as slow as I’d like. I am using an old standard COX muffler.
    The prop is a COX 5x3. Engine runs well but the idle is a bit high 5-6K.
    I live at 5000’ above sea level. I would like to get it to idle at 3-4K if possible.
    I have several questions which are as follows:
    1. Did the .050 TD RC have SPI ? My .051 TD has .004”
    of SPI and screams with the normal intake setup.
    2. Is this SPI the reason for not being able to get a slow idle?
    3. How should the air bleed be setup and is it critical how it
    is set for low idling?
    4. Could the size of prop. influence idle speed?
  2. #2
    Join Date
    Oct 2007
    , GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 051 Tee Dee Cloning to a .050 Tee Dee R/C
    FYI...
    The Cox TD.05RC used piston/rod/cylinder assembly part #20145. The cylinder is marked #5 in the exhaust port but it does not have SPI.
    It is ground outside around the port for the special muffler assembly.
    This cylinder assembly is very difficult find ,since so few complete engines were made, naturally only a small number of service replacement parts were produced also.
    Good luck in your search for hens teeth.....
  3. #3
    Mr Cox's Avatar
    Join Date
    Jul 2007
    Karlstad, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    1) the .05RC does not have any SPI
    2) I don't think SPI is any good for the idle, but the Norvels do quite well with SPI
    3) you the airbleed screw as usual, i.e. for a good throttle respons (this is a little richer that just right for constant rpm). On the 05RC the screw covers about half of the hole.
    4) A larger prop, e.g. a 6x3, will idle lower and a lower compression helps too. The high compression TD head is a little too high compression, you'll need a few head shims depending on the nitro level. A lower nitro level can also bring down the idle.
    I think you might have too high expectations, there are very few 1/2A engine that idle reliably below 4000rpm and other that possible awe-factor (?) you will actually not need anything below 6-7krpm when flying, especially on a 5x3 prop. I think you should set it up for maximum high-end performance and then simply live with what ever low-end you get.
    I've had my 05RC idle down to about 4000 on the bench (but don't need it for flying):
    [youtube]http://www.youtube.com/watch?v=xEGKeaqu8Go[/youtube]
  4. #4
    Cox International's Avatar
    Join Date
    Feb 2009
    Williams Lake, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The reason your 051 does not idle al low as an OEM 050 is because 051 has SPI and 050 does not. Switching to our TD (non-SPI) cylinder/piston will put you on par with an 050.
    However, your current setup should idle around 5,500 - 6,000 and should be good enough for RC flying.
    Another method to reduce RPM is to use our "type A" head conversion with the hot insert.
    Bernie
    www.coxinternational.ca
  5. #5
    Join Date
    Jan 2010
    naples, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got a good one here with mainly after market stuff from Cox International/Bernie. Old Tee Dee .049 with a MECOA long reach glow plug adapter, an O.S. A5 plug, Cox International's "Tee Dee Power non-SPI" piston/cylinder assembly, Cox International's Tee Dee R/C carb, three head shims from Cox International, an aluminum carb mount body Ipurchased on ebay (ridenfligh I think-his parts are exceptional), an APC 5.7X3 running on Sig Champion 25% with one ounce of castor oil added to each quart of fuel.
    top end 15,000 RPM
    idle4,000 RPM
    transition GREAT
    High end can be raised substantioally, but at the expense of idle.
    Bob
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1663188   Click image for larger version.
  6. #6
    Mr Cox's Avatar
    Join Date
    Jul 2007
    Karlstad, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Giving away 3000rpm at the high end is not worth the lower idle, anything around 5-6000rpm is fine for practical use.
  7. #7
    Join Date
    Jan 2010
    naples, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mr. Cox,
    You are aabsolutely right. However, I occasionally fly out of my front yard and it is heavily wooded with thick and tall pines, palms and oaks. My landing area is narrow, short and closely surrounded by trees. I normally fly electrics at home just so I can kill the power completely to make it in but sometimes I just need to put up a plane with a heart and soul (wet powered) and it breaks my heart when the planes end up spending several nights out in the trees because of my dumb thumbs.
    You are right about the large sacrafice on the top end RPM though. This same engine with a #4 cylinder and a Galbreath head and Nelson plug would run beautifully from about 6,000 RPM to about 18-19,000 RPM with this prop and fuel. This would be a great power range for most planes.
    Besides, I also wanted to see how low I could make this baby idle just for kicks.
    I wlll try to get a pic of my front yard up soon so you can see what I mean. Also, the sound of a whining Cox still draws lots of attention from the neighborhood kids.
    Bob
  8. #8
    Join Date
    Jan 2010
    naples, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    First pic was taken about where I turn base to final, second was taken from about where I stand when flying-looking at the area where I turn base to final.
ID:	1664038   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
