Silver case Tee Dee.
Bought a Tee Dee with a silver case. It appears to be aluminum instead of plastic. I thought they were all either red or black. The color is the size is this something other than an .049 or .051?
RE: Silver case Tee Dee.
If you're talking about the venturi mount, it may be one of the aluminum aftermarket products. If the engine is an .051, it should have a ring around the piston near the skirt.
1 Post
The CNC machined aftermarket metal replacement carb bodies are available from a couple of sources in 010 (red and black), 020 (red), 049(black and natural),051 (red and natural), 09 (black) and 15 (black) sizes. The 'silver' ones are simply natural aluminium. As indicated by proptop-'ridenfligh' is the main Ebay source. He lists these periodically-not on a regular basis. There seem to be two versions-a direct replacement for the original plastic units-and a slightly improved (and more expensive) version, with a teflon gasket and O-ring seal. Certainly useful for the 15 sized engines as any original plastic ones are well and truly gone-but twice the price of the plastic units for the smaller sizes of Tee Dees
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
ORIGINAL: Sport_Pilot
No the part of the case under the venturi, it is normally black or red.
