VA mk I help
QC, CANADA
VA mk I help
So I finally acquired a VA from a forum member! I've wanted one of these gems forever! anyway, as the story goes theres not Venturi insert (not an issue) and no needle valve assembly. I ordered a NVA from Larry (kitting it together) which I use on norvels with success and its too large. I could maybe drill out the hole but even then it would require shims to center it.
Does anyone know where to get one, or have one in their parts bin? Thanks a lot!!
RE: VA mk I help
I can't help you in getting the original part but I have drilled out and used shims for NV assemblies from Larry many times and it's not really much of a problem. Good luck in your search, your gonna need it.
QC, CANADA
RE: VA mk I help
I definetly dont NEED the origional, just knowing I can drill it out and shim it is perfect, thanks!!
you wouldnt happen to know what size the hole I need to drill is would you?
RE: VA mk I help
Guess I'd just mic the assembly. Or use a drill guide and see what hole it fits in. I'd tell ya but the problem is I have more than one type and their all different. When you shim it to put the spray bar hole in the middle of the venturi, don't beat yourself up. It doesn't have to be "perfect" just as close as you can come up with.
1 Post
RE: VA mk I help
As an additional suggestion-Fourmost Products produce 'precision washers'-you get a bag of assorted sizes-these are a very close fit on their nominal size-only a couple of thou' clearance above the nominal ID diameter. These have a relatively small OD-and are ideal for shimming spraybars to centralise the jet hole. The Larry Driskill fine thread NVAs will be imperial size, so the Fourmost washers will fit nicely. Most good model shops should stock the Fourmost Precision washers. [you alse get a range of sizes-some of which are ideal for soldering on undercarriage axles to retain wheels].
ChrisM
ffkiwi
ChrisM
ffkiwi
RE: VA mk I help
One other option: Put a throttled carb on it!
These engines respond to throttling really well-I've used a G-Mark .061 carb on mine, it needed the neck turned down like others probably will but it was very worth it. AndyW has done a bunch of them.
There has been a G-Mark .061 on Feebay for the last couple of weeks it's used, and keeps getting relisted for $35. I'm half tempted to buy it for the carb. You want a crack at it?
QC, CANADA
RE: VA mk I help
That does sound kinda cool DD, I was also thinking of contacting John Fotiu for a peewee penetrator (Ive wanted one for years) to put the VA into.
I checked feebay, the seller wants 23$ for shipping to canada! highway robbery! Ive had plane kits shipped for less then 6$!!
If youre interested in setting it up for me send me a PM and we could work something out
RE: VA mk I help
ORIGINAL: forsakenrider
I gave his number in the other thread-just call him during the day:
586
773
7069
