I need a TD .020 Needle valve and spray bar!
NE
Howdy all!
Thanks for all the helpful suggestions you guys posted trying to help me get my TD .020 running. Last night I ran it on a engine stand. While adjusting the needle valve it completely fell out! I need a new spray bar and needle valve! The threads are totally stripped out! It will only thread in about half way and that's where she stops! No wonder the engine ran so rich. I guess there is no way to fix it other than replace the spray bar and needle valve. Too bad cause I McGyvered a cool external tank for it. I took a TD .049 tank mount and sawed off the mounting beams flush with the tank. I then simply drilled two holes in the mounting beam cross section for the TD .020. I did get one good run last night and it ran for 5 mins!
Hec
Hec
