Profi .049-.061s...????
They've been out for SEVERAL years by now and I know of several individuals who have purchased some...and you know who you are....
In all this time, there hasn't been any discussion or any threads about how they have done in 1/2A RC applications....NADAthing.
No Radar based speed claims.....
No doppler based claims, no clockings, no onboard data systems reports, just DFSilence.
What's the deal..?
What's the deal..?
QC, CANADA
RE: Profi .049-.061s...????
I will get myself one for christmas I think. so expect something in the spring (winter is toooo darn cold up here for nitro)
My Feedback: (19)
ORIGINAL: vertical grimmace
It is a shame they are so hard to aquire
Edit: Engines are now sold.
The problems for me twofold:
1) I don't have a place to fly such an airplane anymore. I about all the flying I can handle on weekends with John at the schoolyard so I don't maintain a club membership anymore-this makes it really hard to fly 140-150mph airplanes without the police showing up. There just isn't much "unused" open ground in the Detroit area...
2) The airframe I intend to use for this has been suffering severe flutter problems at these speeds and I can't nail it down to ailerons or the V-tail. Until the last year or so, speeds as an electric were limited to 120-130mph on 2 cells because the packs would only be good to 30A. Now you can pull 40-50 and I lost one airplane and have had close calls with two others. I suppose I could glass the wings and go to a conventional tail but I would prefer to get a handle on the problem
Next time you have flutter with no way to shut it down, just do consecutive loops till it shuts off. I set my linkage up for both the ailerons and elevator so that the push rod connects to the control horn at least 7/8" above the top surface of the control surface and the servo end is usually the inner hole on the arm. 2-56 push rods, either with a guide or with fiberglass tubing slid over the 2-56 wire if it's a long, unsupported run. Slop free aileron torque rods are done by greasing the rods and inbedding them in puddles of thickened epoxy.
Sealed gaps are nice, but not absolute musts. I've got some pretty "looney" planes setup with big elevons, stabilators, V Tail [like you laid out how to do] and flutter almost has never happened here, but the Bat Outta Hell flying wing had a slight case of it and I can't remember what cured it. Might have been a servo with backlash that got changed out...?
If it wasn't for a real nice hay farmer I wouldn't have a flying field just down the hill from my house. Part of my reasoning for moving out to an agricultural zone 20 years ago had to do with not just this hobby, but being able to use the local roads to test my hot rod Chevy.
Ironically, the new Sheriffs office is built on one of the streets that I had 1320 foot marks painted on it. 20 years ago there were very few cops, now this place is crawlin' with The Fuzz.
QC, CANADA
My buddy here was having flutter issues he thought were coming from the ailerons. Turns out it wasnt that at all and actually the tail feathers. he made a new stiffer set of tails and used kevlar live hinges instead of tape and he had no more issues. If your wing is foam core you can also melt the LE of the aileron with a soldering iron and put in a nice bead of epoxy to stiffen it up.
MN
I did notice while following links from Toad's new site that "hobbyclub.com" does seem to have these, the new Fora, and a few other hot ones in stock at semi-reasonable prices. Anyone ever ordered from these guys?
I'm probably one of the guilty "no-speed flight yet-ers" As I still havent flown my last winters build "AceHeaven" SWR with the 1CC FORA. But I think you know how that mill runs though CP I have cranked it up in the garage a few times to hear the scream and get used to the bladder engineer position, And the wife and I took it across the road to the park for some test glides(I figured if it had enough up-elevator to keep it in a slightly nose down glide when tossed that would be just right for flight) With the late snow-melt off and flooding(and overloading myself on other projects this last year it was just too hard to find a place big enough to try er at the right time. (excuses,excuses)
I'm thinking about bolting on a AME 1cc or a TD for a test flight so I can build up confidence to toss it with the screamer. Yes, I feel lame[] But don't worry too much! , I do, to my neighbor's delight run all of these engines regularly in my smoky garage! It would probably be "hoarding" if I ordered a Profi before I fly this one , right? Todd
Your model look great Todd.......but in the wing's scale position I think the plane has too much side area forward of the CG.
If you recall, I ended up performing surgery on my Corsair to move the wing way forward.
It would only flat spin on launches before I changed it.
The other option would have been to increase the size of the fin / rudder.....but I figured that would have made the plane less recognizable.
There are some things I can do to stiffen the airframe up:
The Ailerons are driven too close to the root which makes the tip more free to vibrate-this is a 5/8" thick bagged foam wing with 1/32" balsa skins and glass for the hinge-there's not a lot of rigidity because they are just so thin. I'll also consider not cutting out the slit for the tip and just letting the aileron flex when moved by the servo. will also consider carbon mat under the skins, but I have had warpage with it in the past over time.
Tail: They are going to have to get spars and glass. I strongly suspect it is the tail that is causing the problem. The last crash totalled the airframe, but there didn't seem to be any damage to the ailerons. I heard a quick buzz and lost control-I was only 70-80 feet off the ground so it was over about the time the throttle hit the bottom stop.
The elevator surfaces have an odd shape to me, by going larger at the tip you may invite flutter there?
On my QM planes the moving surfaces are shaped in the opposite way, i.e. tapering off so that there is less area near the tip compared to the base where you have better support. Great looking stuff otherwise. I'm gathering building material, and courage, for a SWR build this winter...
Edit; It seems I have confused images and who had flutter problems here. Any pictures of yours DD?
I think I saw the Fora .06 somewhere recently for about $170.They had the Profi for $150.I was tempted.HobbyClub. I think they are available. I would rather get one of them than 2 Norvels. I never dealt with them before so I can't recommend them. They seem somewhat more expensivefor some other motors, but it is only money. I figure 10% who cares, any more then it is serious.
ORIGINAL: Truckracer
I have (2) Profi .061 engines I would sell. In very good, almost new condition and they run great! Mine don't run quite as well as a Cyclon, but darn close. I have the Nelson and Turbo heads ..... could never make the Turbo head run well at all. Nelson head works great. I tried to get a 1/2A pylon class going here using these engines....
Oooops.........I didn't see your earlier post truckracer. You would be the first that I've heard who got some use out of the Profis. How did you run your's..?
[and don't say "clockwise", that's an old, corny joke.......]
I saw a couple of Profis (I think) at Muncie, I was told they were unobtainable but the Fora maybe was.. They sounded wayyyy better than the Tee Dees. They were running really small props like the combat tradition. They were in the 1/2 A combat planes so I am supposing .049. When they hit the ground the motor mounts on the plane always seemed to break off probably because they hit harder. The planes were fairly big, almost as large as the F2D. I think one was a Yuvenko and it looked like my F2D, but was a bit smaller. They were almost as fast too. Don't know about longevity or any details, but they sure sounded high pitched, maybe over 35,000 rpm. I want to get one for 1/2A speed but was told the piped CS was better.(I don't think so myself)
My Feedback: (19)
I also have a Profi 0.8 sitting around. I haven't even bench run it. I have an electric pylon racer I was going to put it in, but realized I can't fly the thing at the club field because it's not muffled. There are no "outlaw" fields that I know of, so it just sits until I can move to the sticks. One of these days I'll put it on the bench and irritate the neighbors.
Hobby club does have the Profi .049 in stock for 149. CP, you have seen heard bad things about them? Or did I mis-understand?
VG, I've haven't heard anything locally about the Profi....but that shows how long I've been away from the local control line scene.
Years ago there was a thread at the MACA message board about how 1 guy's engine wouldn't hold a needle setting and that's the sum total of the Profi related message traffic...[besides all the proud announcements of RCU guys who own one but never run / flown it].
$149 is a great price, that's what I paid for a .049 Fora almost 10 years ago. The Fora was fantastic, never even had the head or backplate off of it and got literally hundreds of runs on it.
Aspeed......The backplate mounts broke..?
I would mount the engine to the center rib with a single 2-56 threaded rod and nylocks so that the engine is free to swing to one side at impact. The single bolt has plenty of clamping force to keep the engine straight. This is how I do my 1/2A RC flying wings
CP The couple I saw break were the foamy planes. I noticed that because I have one at home that ....I never got around to finishing and flying, like everyone else. I was just going to use a Norvel but the Profi caught my attention with the intake turnedup and the power it got.I mostly bothered the guys at the speed circles and stopped by the combat area when I could. I saw an article from the 1960's that had a plane called the Bamboozle that had a sheet alum bracketthat thebackplate screwed onto that pivoted up on elastics for hard hits. It had a cardboard wing and a bamboo stick for a fuselage. It had a combat plane and a trainer variation. Kind of a SPAD before its time. I made a similar combat with a Tee Dee with the coroplast in the early 1980's based on that. It still works good and is in one piece. The nylon control horn is the only thing that ever broke, and that was mostly due to old age brittleness. (and a crash) The 2-56 screw sounds good too for the Russian ARFs. Maybe I'll use two nylon 4-40 bolts or something on my foamy. I should finish that over the winter. The other forum guy that had the problem with holding a setting could maybe try the Little Red Cap bladder. It is kind of a squirrel sized condom made for capping caulking tubes so they don't dry out. They have way less pressure than the tubing.I got a pack of 20 for $5. They are maybe a bit thicker than a balloon. I think the reason no one uses the Profi for rc is because there is no throttle, My rc club calls for a means to shut off the motor, and a muffler. I flew my combat control line there though. I think that is ok.
