Pee wee tank overheating.
I've heard this quite a bit, and I'm curious if there's any truth to the matter, and if so, are there any fixes?
I wouldn't mind running a tank out on my pee wee's once in a while!
RE: Pee wee tank overheating.
If you do a thorough tear down of any 1/2A engine and do a step by step reassembly starting with a sonic cleaning of all parts then detailing the crankshaft's fit in the case, you will solve a good percentage of run away heat buildup issues. Chuck the very tip of the crank into a drill press, lathe, etc., and polish the main journal with 800 grit or finer paper. Do not go a billionth of an inch overboard doing this, do lots of trial fits to see how well the crank spins with just the flick of the prop.
Check the fore and aft clearances of the prop drive assembly.
As you reassemble the engine the fits of all inter-connected parts need to be checked and looked at under magnification, especially the piston / liner.
Look for gouges, ridges, bumps, shiny wear marks on the piston, etc.
Just a cheap jeweler's lens will reveal lots of nasty stuff sometimes.
I was struggling to get consistent runs from my peewee, it would only empty the tank if I compensated a little on the needle throughout the run. I tried different props and head shims etc. but didn't manage to solve it. To me that was related to the heating of the tank simply because it is attached to the crankcase. Mine didn't have a particularly tight crank (quite the opposite) or any other problems that I could see.
I was going to try an external tank (which works well on the Babebees) but I never got around to do that. Instead I converted it to diesel and now it empties the tank everytime. Disels are less sensitive on the needle, they can miss but don't stop, but the engine also runs a lot colder.
One thing one could to try, without drilling a hole in the the stock tank, is to put one of the yellow helicopter backplates on it and see if the needling problems go away with an external tank.
The first thing, of course, is to make sure the fuel pickup goes all the way to the bottom of the tank bell.
The other is that these engines need a blast of air over them to keep the tank cool. I've seen two cases of close cowlings with Baby Bee's that led to the fuel in the tank boiling.
If it's an exposed engine then it would imply that the crankshaft is too tight in the case and the fitting described by Combat Pigg should solve the issue.
I had planned to have a cowl around the tank area but I never got that far, given the running problems I had. Might still try the external tank though, I should have one of the helicopter backplates somewhere.
Has anyone ever tried to put an intake throttle/choke on the PeeWee, a small conical rod in the intake connected to a servo might do it?
Before I fly again, I'll be sure to wear some xray specs and check the crank fit before flicking myself to death again.
Incidentally, the engine is all out in the breeze as I managed to snap the cheek cowls almost every time I started it!
Don't forget to deburr the threaded tank mounting holes on the crank case and deburr the mating holes on the tank. RTV will confirm if it's an air leak, temp related or otherwise by applying to the tank/case junction and the backplate/tank interface.
I found on the Baby Bee's at least that the crankcases were too sloppy after a while and they wouldn't hold a setting. This would give an inconsistant run, rich,lean,rich lean. This could cause it to run hot. As the fuel runs low, it will not cool the tank as much too. I found if you pull the crank forward and try to rock it up and down with the prop, and there is slop with the piston moving up and down, that is the culprit of an uneven run. Assuming a good o ring and reed etc. If you have the crank out there is a half moon wear spot at the bottom of the crank bore near the back that is the giveaway. I really don't like to run the reedy ones anymore. Too much maintenance for air time. I made a couple of cases with bushings to solve this and it helped. So would a new case. I wouldn't lap any cranks myself. It just speeds up the wear cycle.
That's a good point.
If the crank fit is already worn out, you don't want to lap the crank.......
The only .020s I've had my hands on were too tight.
Regardless, the heat from a good running engine, [even a screamer] should never be enough to make the tank hot enough to fry an egg.
The smaller these engines are, the more perfect everything needs to be.
LA
ORIGINAL: combatpigg
Al
P.S. As an aside my School Boy was overweight due to the available radio gear of the time. When Ken Willard designed his School Boy, Page Boy, etc. he was able to use super-regen receivers on the citizens band such as the postage stamp sized Otarion. (Believe it or not, they were comparable weight wise to our modern micro receivers). The upsurge of the CB users soon rendered super-regen receivers useless for R/C. Thus my selection of the new (at the time), but heavier, Ace super-het double-ended reciever and Adams actuator which comes in at 2.96 oz (I still have it and just weighed it). As a comparison; with modern micro R/C gear an all up weight of 4 to 4.5 oz for an entire .010 model with two or even three full proportional channels is the norm.
Al
Mine didn't get particularly hot, in the sense that it would boil the fuel. But on a cold day there is a substantial change in the temperature of the crankcase (and the tank) from the start till the end of the run. On the ground I could run the tank out if I fiddled a little with the needle after about half the run, it was very small changes but it was enough to not be able to have a sweet run from the start till the end. Any other problems, like a leaking o-ring on the venture etc will of coarse add to the problem and make it even worse.
It just feels like it is very sensitive on the needle, and the temperature change of the tank just makes it even worse. I have had similar problems on a Babe bee and it ran much better on an external tank, i.e. giving very consistent and long runs.
Any engine that cant handle subtle changes in fuel head pressure is deficient in the basic things that promote spontaneous combustion from start to finish.
Compression......good compression also promotes good fuel draw
Crankcase seal.......directly effects fuel draw and pumping action
Friction free and smooth operation of the moving parts
Condition of the fuel and the glow plug
Plumbing problems, including the critical seal between the built in tank and the air intake passage.
A tired engine can have extra time squeezed out of it by running less prop, no head shims and up to 30% oil and bladder pressure. De-pitch the .020 prop by twisting it with your fingers.
I don't use the built in tank for RC applications as a general practice. All it is to me is a motor mount.
I'm happier with the results of using a remote fuel tank for RC projects.
Al, if the engine was in good shape you could always try more oil and less prop. Just scrape some mass off the fat part of the plastic blades with your exacto knife, trim a tiny amount of diameter off, de-pitch the blades a little.
I expect all engines to pass some sort of a leakdown test. If you duct tape the exhaust ports and rig up a hose to force air into the intake, you shouldn't see leakage around the head or the snout of the crankcase. Turn the engine over slowly and observe. It helps to have the engine in water to see where the air bubbles are coming out. I know a guy who owns a small engine shop who can quickly plow through a barrel full of weed eater engines with this test and evaluate the ones that are worth spending time on and the ones that are useless junk.
