50th Anniversary Flight - Pageboy
RE: 50th Anniversary Flight - Pageboy
Press on with your project. I may or may not get my 50th Anniv flights done by the 24th due to high winds and life issues. It'll happen sooner or later.
MN
Got all the parts cut out today. May be able to glue up fuse or wing tonight.
Question: How do I hold the ribs down while sheeting the wing? There doesn't seem to be enough room to pin down the ribs to the board and there's no spar or anything to glue them to in order to keep them from moving.
Tim
Tim
My Feedback: (98)
I'm not sure it's how I did mine, but in the past I've dusted 3M77 on the plans then put wax paper over the plans. After you have that down spray the wax paper with 3M77 and stick the ribs down. You can put CA on the ribs then put the skins on, or use wood glue on the ribs and weigh the skins down with sand bags.
It's been a while but I think I tacked each rib at the leading edge with the trailing edge hanging a little over the edge of the table, then carefully pulled the skin down and tacked it to the rear of the ribs. After setting, I removed it from the table and finished gluing the ribs to the skin with CA. Working carefully, it can be done without warping it. Good luck.
#31
MN
Tee Bee, I ended up doing it just the opposite. I pinned the front of the ribs down over the plan and then put some medium ca on the back, carefully gluing the sheeting down on the back 1/4 inch only. Then I pinned that edge down, pulled the pins from the front, used medium ca on the rest of the rib lengths, and pressed the skin down. Worked well.
My Feedback: (98)
Test flew mine for the first time since the fall. Blew the prop off, mines got a little electric motor in, it that uses 5x2 props that I glue on the 1mm prop drive. It'll be roaring on the 24th.
#33
MN
Got the wing done last night. Had to work tonight so didn't have a chance to work on it. Will build the fuse tomorrow night.
Regarding the finish, I just thought I would use some clear, low shrink butyrate dope. I'd like to thin it but not sure how far I can go with it. I plan on brushing it on. I thought two or three thinned coats would be best with light sanding in between to knock down the bumps. What suggestions does anyone have on the ratio of thinner to dope? ...Or does the TLAR (that looks about right) method work?
Tim
Tim
#35
TN
I did mine basically the same way Tee Bee did his. But then I put 1/32 sheeting on the bottom also. I raised, and rounded the leading edge, and added ailerons too.
I've ordered the motor, but don't know when it'll get here. I still have to clear it, and add some color trim.
I built mine while I was scratchbuilding the DR-1
Pat
Pat
#36
My Feedback: (22)
ORIGINAL: exocet-RCU
Tim
Tim
John
#38
MN
so what throws should I have for this plane? It was originally designed for rudder only but I added elevator. Any thoughts? Also, where should he CG end up? Top of the arch in the wing chord?
Tim
Tim
#39
TN
Ailerons?
I added ailerons because I like to beable to do rolls, and tolevel the wings on landings, and I like to fly inverted. I took out the dihedral, and also added a elevator to it.
You going to do a thread on the Triplane?
Been thinking about it. I took a bunch of building pictures of it.
Pat
#41
Pat -
That's a slick way to set up aileron horns - I've never seen that before. Are you using tubing or wire insulation. For light weight applications, I would bet that silicone insulation from the high strand count wire would work nicely - very flexible and not too prone to fatigue cracking.
andrew
andrew
#42
TN
Andrew,
Yep, it's wire insulation from some smallhigh temp wire I have. I believe it's silicone. soft yet strong enough, and holds tight! It's easy to adjust, but stays where you put it. Best thing is it's alight weight setup.
Pat
Pat
#43
Tim, sorry for the late reply regarding the throws. I got mine down from the ceiling tonight to check it out and prep it for flying tomorrow for the 50th anniversary. Anyway, I realized that I never got around to programming it to the DX8. I used to use a DX6i and I didn't save the previous data when programming all the planes to the new transmitter. Sooo, now I've got to start over adjusting the hi/lo rates. That's a shame since I had it dialed in the way I liked it last time out.
Sorry about that. I hope to do some testing/tweaking tomorrow and get it dialed in again.
#47
I got two flights in on mine today. Woohoo! I tried to run the prop backward as Ken Willard did but it kept flying off during the startup. Then I attached it normally and flew it in "high gear".
One of our club members shot the video for me. After I get it loaded, edited, and uploaded I'll post the link.
