Did you ever want a fantastic, powerful .061 diesel?
Well, if you ever did, you better get ahold of one of the few remaining second run MP JET .061 BB/RC's left. MP JET has stopped making them again, which is a real shame. These are very powerful motors and offer more prop size choice than a glow motor of the same size could ever dream of. Build quality is very high and they handle well.
When these motors came out they showed how truly good a small diesel could be once someone who wasn't lost in the 1950's made a small diesel.
This is one of those engines you guys really, really want to experience. At $125 or so they aren't a whole lot more expensive than a night out. Just bite the bullet and do it, you won't regret it. After the last run dried up I was paying upwards of $200 for these and have amassed 5 of them-they are that good.
RE: Did you ever want a fantastic, powerful .061 diesel?
I only had two of these from before, so I've done my hoarding and got two more from the latest run...
Don't forget about all the nice accessories that MP Jet makes, there are aluminium propnuts and spinners that are dedicated for these engine too.
MN
Carlson lists the MP Jet, but no info on the site..
http://carlsonengineimports.net/
I bought my 061 glow R/C from them many years ago.
Dave
Dave
I've bought from a local dealer and also from topmodel.fr, but I think the shipping from them to the US is expensive.
Here is the engine with the dedicated propnut on it;
I CARE RC Quebec Canada has a new batch 125$ US rc carb , c/l carb a few bucks less have one just ordered 2 more today
available from Australia also David owen martin
ORIGINAL: vicman
Who's got em?
Who's got em?
ICARE R/C in Canada also sells them, I'm much less favorably impressed with their service. Since orders from David take 10 days, there's really no reason not to just go with the better dealer.
ORIGINAL: Mr Cox
Topmodel's shipping is OUTRAGEOUS!!!! I once tried to order a 30mm MP JET spinner from them and the shipping was $35!
http://s29.photobucket.com/albums/c2...Caudron_01.mp4
http://s29.photobucket.com/albums/c2...Picture101.mp4
Would you believe these are both powered by the same engine? The fast airplane is RocketRob's JMGlaskraft Caudron, spinning a 5.5-5.5 in the 20-21k range doing a little over 100mph on doppler. The Taylorcraft was Steve Staples' at SMALL turning an 8-4 prop. He hadn't started the engine in some time so it took a bit to get it runnning.
Most of the time I am starting mine up they respond to a prime and flip just like a glow motor does-the compression for starting is really close to the running compression, I just leave it where it likes to run and treat it like a glow motor. The way one of these motors spins a Cox 6-4 makes a Norvel .074 tuck tail and run!
Just watched a break-in video on youtube with one of these turning a 7-3 at 15,300 with the compression setting light enough to still be be mis-firing. I don't think an OS10FP will do that, will it?
An OS 10FP will do about that on a 7x4 prop. The MP Jets are good but there are limits...
Apparently the Norvel .061 on diesel, is comparable to the MP Jet.
ORIGINAL: Mr Cox
http://s29.photobucket.com/albums/c2...cture004-1.mp4
My Feedback: (17)
TX
Hi group. I'm getting back into 1/2a and have a question about these diesel engines. Does everyone make there own fuel or perhaps ya'll are purchasing it somewhere. the only place I see to purchase fuel
is the "Diesel Doctor"...
thanks,
Xanaphyst
thanks,
Xanaphyst
MN
Always made my own for my PAW 055, 1/3 Kero, 1/3 Sig castor and 1/3 John Deere starter fluid.
Bigger engines (and just about all are bigger than the 055) may run better on other ratios.
The smell of ether permeates everything.
Dave
Dave
ORIGINAL: xanaphyst
is the ''Diesel Doctor''...
thanks,
Xanaphyst
thanks,
Xanaphyst
ETA: The most important thing I have found with fuel is to have a way to store it that won't leak your ether out. You have to have a DARN good seal on your fuel container to keep it from going bad, the ether just finds a way out no matter what. Factory sealed containers even smell like ether and they use pip tape to help seal the caps. Again, if the fuel goes south it just takes adding a little ether to make it fresh again... It doesn't harm the engines one bit to have low ether, it just makes them hard to start. The engines don't even need ether to run-you can start an engine on ether fuel and switch to straight kero and oil mix once it's warm. The compression and needle settings will be slightly different, but the engines run great once warm. You can also add 1 or 2% DII (diesel ignition improver) to help things along, a lifetime supply is $15 or so.
My Feedback: (17)
TX
Sounds easy enough. Thanks for the info. I've emailed both Carlson and Icare to see if I can get my hands on one along with a rebuild kit.
As regards performance, my 061BB diesel turns an APC 7x3 at 17600, which puts it well into Norvel 074 territory. (The dieselised Norvel 061 does about 17000 with the same prop.) I prefer either my glow or diesel MP Jet 061s to my Norvel 061s.
Where has the info come from that MP Jet are no longer making them? Dave Owen hadn't heard anything to that effect yet.
I'm not sure where the info originally comes from, other than a rumour, that is.
Topmodel used to have these listen as in-stock, together with spare parts and accessories, but now they only have it on-order. It is the same for other local sources here.
You can often route the exhaust away from the plane with out loosing too much power. But I know what you mean, at the field in not much of a problem though so the key is to not get the exhaust residue on your clothes and to clean the plane well and the field (and leaving the paper towels there).
An engine with muffler on a plane that can ROG is often enough, just stay away from hand launching cox engines that run on diesel....
ORIGINAL: Mr Cox
ORIGINAL: steve111
The MP Jets is just sooo much nicer an engine than a Norvel, and I don't say that lightly-Norvels are very, very good.
As for the rumor, the post I put in my last reply has the information. Sounds like David Owen might know about it now, who knows.
I have 2 MPJet diesels 061s on the way with exhaust spacers on the way from I Care RC Quebec Canada, expect them by end of the week martin
