"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Modern Hobbycraft FW-190
Old 03-04-2013, 10:34 PM
My Gallery
My Models
My Feedback
Default Modern Hobbycraft FW-190
I posted this previously in probably the worst place possible. I believe it would be better suited here. Has anyone built one of these for r/c? I'm interested in doing one up using the plans found here
How do you think this will fare as an rc aircraft. I'm completely new to rc and currently have a sig lt 40 nearing completion. I'm really enjoying building and that is what I want to do. I dont mind failures as long as I feel im not wasting my time getting to a fun and successful build... although im sure not all will be succesful.
I was going to up scale a 406 guillows fw190 i have to 36 inches but also saw this.
dce21b is offline
Old 03-05-2013, 01:42 AM
My Gallery
My Models
My Feedback
Default RE: Modern Hobbycraft FW-190
I do it all the time but I change the airfoils and incidence angles to better suit rc.. for example I took a similar type aircraft and changed the airfoil to a S6063 at 1 degree pos incidence, kept the elev at 0.. all the usual rt thrust and down thrust for engine with a 10 comparable outrunner and 9 X 7.5 apc prop... I say do it man cause then you'll have something you really want to fly anyways....I take alot off freeflight plans and convert them to parkflyers.. something at that size will need a 150 to 300 watt electric or nitro comparable.. hope this helps ....
guamflyer is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
