OK Cub .19
My Feedback: (38)
OK Cub .19
I have 2 identical OK Cub .19's except one is stamped .19 the other one reads as exactly as shown. There's a little .1 a 4 and a little 0. They are exactly the same size wise. Does this seem odd?
RE: OK Cub .19
There was a Cub 14. I would make a guess that the 19 is a bored out 14. If so, and you have a 14, the cylinder wall should be thicker than your 19. All speculation, of course.
RE: OK Cub .19
You don't see many .19 or .149 OK Cubs around, so you must have a rare find, jsesere.
I don't know why they referred to it as a .149 instead of a .15 or .14. Might have something to do with use in say competition free flight or else, beats me. Enya called their .099 a .09, like in the .09-III or .09-IV. Somewhat deceiving but knowing such puts things into proper perspective, I guess. [:-]
RE: OK Cub .19
ORIGINAL: GallopingGhostler
Actually back in the day the .149 was referred to as a "Cub .14". Its actual displacement is larger than the K&B .15...
When it came out it was a "powerful" engine for its size.
Here are mine... .19 on left, .14 on right.
George
RE: OK Cub .19
That is interesting, George. Seems almost like they used the same crankcase. Well, you don't see those often. They almost resemble the smaller displacement Enyas, .049, .06, .08.
