Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Build Thread: Selextra 500
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 07-12-2013, 07:15 AM
  #51
hfenn
Default RE: Build Thread: Selextra 500
ORIGINAL: hfenn
@guamflyer Thanks for following! I haven't settled on a trim scheme yet. I've been looking at pics of full size Extra300L for ideas.
@Andrew I did not hollow the bottom of the front block. It was very good wood and the part you could hollow is very close to where the CG will be, so I don't think the few grams would be worth it. Re the turtledeck stringers at the tail: I'm sure Steve will chime in, but we had that conversation. I'm inclined to do it as you suggested if I were scratch building, but Steve pointed out that it would require another wood size to be included in the kit. After having this in hand, I believe it will be easy enough to cover as is. I will detail how I tackle the covering as I get to the that part of the build.
Thanks all for following along. The thread has gotten a fair amount of views in just over a week.
I see Steve was typing while I was and already remarked about the tail fairing.
Old 07-12-2013, 07:59 AM
  #52
Andrew
ORIGINAL: skaliwag
I agree. On the proto I did shape two 5/8 sq blocks. I am going to kit this model and 6 inches of 5/8 sq costs more than a few inches of 1/8 sq balsa. Sqquueeeeek.
I suspected the additional wood size may have been a factor in your design layout. OTOH, most folks who undertake building from a kit today are likely to have enough scrap wood laying around to make the modification if they choose.
Either way, it looks to be a great model and Hollis is certainly doing it justice with his build thread.
Old 07-12-2013, 08:14 AM
  #53
skaliwag
skaliwag's Avatar
Absolute agreement on all counts.
Old 07-12-2013, 11:25 AM
  #54
Tee Bee
Wow! Nice build, Hollis. I've been away from this place for a while tending to other things and was pleased to see this thread when I dropped back in to see what was happening here.
Old 07-12-2013, 04:53 PM
  #55
hfenn
ORIGINAL: Tee Bee
Thanks Tee Bee!
Old 07-13-2013, 05:40 PM
  #56
SnApRoLl-
Nice build.
What's the price of a beta kit? I'm interested in building one.
Old 07-13-2013, 05:56 PM
  #57
skaliwag
skaliwag's Avatar
SnApRoLl- PM sent
Old 07-14-2013, 06:01 AM
  #58
forsakenrider
Me too skalywag, now that Im back from vacation, how about that kit I wanted before?
Old 07-14-2013, 06:22 AM
  #59
skaliwag
skaliwag's Avatar
forsakenrider
Email sent
Old 07-14-2013, 10:09 AM
  #60
cortacesped
Skaliwag:
Pls send me information about the "International" kit.
Claudio
Old 07-14-2013, 10:21 AM
  #61
skaliwag
skaliwag's Avatar
Hollis is building the International kit, which means that the Long wing pieces are cut in half and have to be joined. If you look at the first few pictures you will see that it is not a problem with the integrity of the wing.
Old 07-14-2013, 04:00 PM
  #62
cortacesped
Yes I know Steve, but I´m interested in the price plus S&H to South America
Claudio
Old 07-14-2013, 04:11 PM
  #63
skaliwag
skaliwag's Avatar
cortacesped
PM and EM sent..
Old 07-14-2013, 06:20 PM
  #64
hfenn
Make the engine clearance cut in the cowl top block. I used a sanding drum on a Dremel for this.
ID:	1900473   Click image for larger version
Old 07-14-2013, 06:22 PM
  #65
hfenn
I like to have a little triangle stock around wing mount plates. Steve will make a change to the drawing and kit for this.
Old 07-14-2013, 06:32 PM
  #66
hfenn
You will need to cut some clearance into the wing hold down block for the rearward action of the aileron torque rods.
Old 07-14-2013, 06:53 PM
  #67
hfenn
Here is how I chose to make the wing fairing. Slot some wax paper or plastic to keep from gluing the wing to the fuselage and slip it over the wing tongue. Bolt the wing in place. Next, glue down a scrap of 1/8" square balsa to the leading edge as shown. Glue on a piece of 1/16" balsa sheet. Remove the wing and fill in the voids with light weight spackle.
ID:	1900485   Click image for larger version
ID:	1900486   Click image for larger version
ID:	1900487   Click image for larger version
ID:	1900488   Click image for larger version
Old 07-16-2013, 11:06 AM
  #68
hfenn
I'm making the final preparations for covering. I've cut out and glued the 1/32" plywood elevator plates, cut the ailerons from the 1/8" balsa sheet stock and beveled the control surface leading edges. I also finished rounding the wing leading edge. I had only done the middle part for fitting the wing to the fuselage.I won't do a step by step on covering the airplane as this is not a beginners tutorial, but rather a build thread. I'll fit the ailerons to the torque rods and then finish sanding and shaping and move on to covering.
ID:	1901197   Click image for larger version
ID:	1901198   Click image for larger version
Old 07-16-2013, 06:54 PM
  #69
exocet-RCU
What are you going to cover it with, HFENN? I'm starting a Roaring 20 and thinking about what covering to use. Coverlite? Solite? Silkspan and dope?
Tim
Old 07-17-2013, 07:12 AM
  #70
hfenn
ORIGINAL: exocet-RCU
Tim
I'll be using TowerKote. I know there are lighter coverings, but I've had good success with TowerKote on glow models. Also, I happen to have a couple partial rolls on hand.
Old 07-18-2013, 06:35 PM
  #71
hfenn
Now for a little color. I still have to finish the control surfaces.
Old 07-18-2013, 07:41 PM
  #72
exocet-RCU
Looks great!
Tim
Old 07-18-2013, 09:55 PM
  #73
combatpigg
combatpigg's Avatar
Very handsome..!
That's a nice combination of colors and the canopy looks perfect.
Old 07-19-2013, 06:24 AM
  #74
hfenn
Thanks Tim and CP!
Old 07-19-2013, 11:38 AM
  #75
hfenn
Let's add some cockpit detail. The pilot has gone off somewhere, probably drinking in a bar. It'll probably take all night to find him.
