Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Re-post engine power output app
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 07-24-2013, 08:46 AM
VUgearhead
Default Re-post engine power output app
There was an older thread that had a link to a PCprogram for calculating power output (or thrust) based on prop/rpm inputs. Unfortunately, the like is no longer active.
Could someone with the app please re-post it here? It sounds like a must have (along with a tach) addition toyour PC design applications library.
Old 07-24-2013, 09:07 AM
combatpigg
combatpigg's Avatar
Default RE: Re-post engine power output app
I can't find "Thrust HP"...but try this.........[link=http://www.lcrcc.net/thrust_calc.htm]prop thrust calculator[/link]
Old 07-25-2013, 10:10 AM
SBS_Pilot
I think there are several of them. The one I usually uses is [link=http://personal.osi.hu/fuzesisz/strc_eng/index.htm]Static Thrust Calculator[/link]. I don't know if it's any better than any other, but I got used to it.
If you don't have a tachometer in the field box there is an Android app, [link=https://play.google.com/store/apps/details?id=org.rcteam.rcheliheadspeed&hl=en]RC Tachometer[/link] that works reasonably well.
/Stefan
Old 08-08-2013, 10:24 AM
hllywdb
hllywdb's Avatar
This is also usefull
http://www.rcpro.org/rccalc/PitchSpeed.aspx
