"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Ziroli 1/2a sukhoi
Reply
Old 09-21-2013, 09:21 AM
xplayer930
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ziroli 1/2a sukhoi
Just got a 1/2a ziroli from my lhs. What modifications cane I do to this little plane? Personally id like to have dual aileron servos and Id like to go with lipo power. But unsure as to what size motor is needed.
xplayer930 is offline
Old 09-21-2013, 11:04 AM
fritzke
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine weighs just under 1 pound ready to fly with an 800mah 3 cell LiPo battery.
I used an old Team Avionics Gust MS outrunner and it flies very well.
1820 KV 29x26 and an APC 8 x 3.8 SF prop
One of my favorites. I used 2 servos for ailerons.
Spray-painted Doculam covering BTW.
Dave
ID:	1923676   Click image for larger version
fritzke is offline
Old 09-21-2013, 06:31 PM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by fritzke View Post
...............Spray-painted Doculam covering BTW.
Dave
Dave ---
Did you spray the glossy side or the adhesive side?
If the glossy side, how did you prep it?
andrew
Andrew is offline
Old 09-22-2013, 11:19 AM
fritzke
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Outside (glossy side), just wiped it down with naptha (or use charcoal lighter fluid)
first. Paint does not stick great, so use low-tack masking materials. Krylon Fusion
is a good choice as it is made to adhere to plastics, but most sprays seem to work.
I used 5 different brands on this plane. Red, 2 shades of green, white, blue, canopy
was black Solarfilm.
Dave
fritzke is offline
Old 10-01-2013, 07:21 AM
DeviousDave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buffing doculam with 3M scotchbrite pad before covering might help pain adhesion..
DeviousDave is offline
Old 10-01-2013, 11:16 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Even though Krylon Fusion may be for plastics, this is related to plastics with some surface energy - ABS, polystyrene, PVC, etc. These are characterized by their ability to be cut by various organic solvents, so the surface can be made active on exposure to solvent and create an aggressive bond with the paint. It is, unfortunately, of little help with low surface energy plastics like PE, PP, EPO, Mylar, the list goes on. Surface abrasion for mechanical grip is a good idea.
MJD is offline
Old 10-01-2013, 12:28 PM
skaliwag
skaliwag's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Krylon Interior / Exterior for years, worked well on the glue side. Seemed to meld with the glue. But they have changed the formula and it no longer works. Does not stick to the glue..
skaliwag is offline
Old 10-02-2013, 04:56 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I've been painting a Multiplex Dogfighter parkie the last couple of days - EPO foam (expanded polyolefin, i.e. the bouncy tough stuff)). It is amazing how poorly paint sticks to it, it becomes like a 5mil shell around the airframe waiting to be peeled off. The laws of science never seem to change - for every good thing there is a negative.. lift/drag, paint/heavy, really cool tough EPO foam/doesn't glue/paint worth beans.. etc
Actually I was experimenting the other day, glassing some scrap EPO from a slightly damaged (ok, trashed) Parkzone model.. I got a reasonably aggressive bond of light glass to the foam using vinylester resin.
Oops the topic is drifting... sorry OP.
MJD is offline
Reply
Display Modes
