Glue sticks for applying tissue
I read about a builder who used white glue mixed with water to stick tissue down to the balsa. He complained about the dried glue coming through the tissue and was very visible. Another fella said that he liked Fuzzee's glue stick method. Does anyone know what glue he was talking about? I think Fuzzee was a contributor. I would like to try the stick method....does anyone have a recommendation as to what glue stick to use? Thanks.
Steve
Glue stick is OK for small electrics but not adequate for 1/2A glow fuel IC, personally I use UHU glue stick for many electric powered indoor project but for IC power I just use dope with tissue since the plane will need dope anyway for fuel protection.
BC, CANADA
White glue, applied to where you need covering (any covering) to stick and left to dry, at least overnight.
Then Iron on the covering. The heat activates the dried white glue and sticks it very well.
Furniture makers have been using this technique for decades.. to apply veneers.
