"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Cox .09 question
Reply
Old 11-29-2013, 05:07 AM
gene6029
gene6029's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cox .09 question
I have posted this question on another site as well to get as much information as i can. I bought this Cox .09 at a local yard sale for $1.00. I couldnt pass it up. I have several Cox engines, .010, .020, .049, but all have attached tanks. My question is what are all the nipples for on the engine? (theres 3). I'm sure the one opposite the needle valve is for the fuel line, & i have been told the one on the body is for pressure. ( to pressureize the fuel tank i guess?) However mine is not drilled open into the engine so i'm guessing its a personal choice to drill it open? Finally there is a nipple on the venturie intake just above the one that feeds the needle valve. Any ideas what its purpose was. ( possible remote prime line???)...Thanks any and all info appreciated, and like i said i'm trying to gather as much info as possible before i try and run this engine.....Gene
ID:	1943299   Click image for larger version
ID:	1943300   Click image for larger version
gene6029 is offline
Old 11-29-2013, 07:07 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel inlet opposite the needle valve.
Side of crankcase on plastic housing - pressure tap, not drilled through crankcase, instructions tell you how to do it if you want to run pressure.
Extra fuel inlet on venturi - flood off for use with mechanical timer (FF).
$1.00? Are you kidding me? You will be envied and loathed by Cox fans for that nice little steal..
You can download the instructions from here:
http://www.mh-aerotools.de/airfoils/cox_frameset.htm
Don't overprop it. 7-4 or COX 7-3.5 if you find one. A good 1/2A fuel, 15% nitro will do nicely.
MJD is offline
Old 11-29-2013, 07:18 AM
gene6029
gene6029's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS ALOT MJD....Gene
gene6029 is offline
Old 11-29-2013, 07:27 AM
Andrew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Wwaaaahhhhh!!!! A buck! I can't believe it. Of course, a man of honor would have certainly offered more!!
Andrew is offline
Old 11-29-2013, 08:20 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Offered more? Ask if he would take 50 cents. It is really old and you can't get parts any more!!!!! ;-)
aspeed is online now
Old 11-29-2013, 08:57 AM
gene6029
gene6029's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Every now and then a blind pig finds an acorn....Gene
gene6029 is offline
Old 11-29-2013, 07:20 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never used the plastic nipple for pressure, I cut it off because it gets in the way of mounting the engine. I do run pressure off a pressure tap screwed into the backplate. As said, probably a free flight engine run off a bladder pressure tank.
Jim Thomerson is offline
Old 11-29-2013, 08:08 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gene - if you didn't already know, the flood off timers counted down, then released - unpinched - a second line from the pressure bladder, spewing fuel into the intake through a wide open hole, and killing the engine "now".
The pressure nipple is fragile, so Jim's method is way more solid.
MJD is offline
Reply
Display Modes
