"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
cox / sanwa reciever battery
Reply
Old 01-17-2014, 03:48 PM
jdwardus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cox / sanwa reciever battery
hello everyone i just got a 3 channel cox / sanwa radio system all is there but the receiver battery . does anyone know the polarity. im thinking hot is on the outside. because the servos red wire is on the outside. i dont want to burn this thing out. any ideas ?
jdwardus is offline
Old 01-17-2014, 03:58 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can check the polarity with a VTVM reads either plus and minus when you put the leads to it martin
and red leads are positive black negative univesal color code
AMB is offline
Old 01-17-2014, 04:49 PM
onecb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes all the plugs are wired the same servos battery. You can check this by the pins on the receiver one row is all the and the center row is all the same. Hope this helps.
onecb is offline
Old 01-17-2014, 05:37 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, compare the plugs on the Cox servos to the connector on the pack you want to use. Some cables will use brown instead of black for negative but they always use a red wire for the positive side.
The label on the receiver or cast in signs on the plastic casing will usually indicate the pin polarity as well.
BMatthews is offline
Old 01-17-2014, 09:35 PM
onecb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As I recall Cox / Sanwa had three black wires with a white trace on the signal wire the opposite side is the positive.
onecb is offline
Old 01-24-2014, 02:31 AM
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This what you need?
http://www.fatlion.com/sailplanes/servos.html
John.
Boomerang1 is offline
Reply
Display Modes
