Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Home made canopy links.
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 01-29-2014, 08:30 PM
skaliwag
skaliwag's Avatar
Default Home made canopy links.
Help...!!!... Looking for the posts about heat shrinking Coke bottles for canopies.
Old 01-29-2014, 11:07 PM
combatpigg
combatpigg's Avatar
Skaliwag...
Dickeybird and Matchlessarrow used to talk about shrunken coke bottle canopies.
The RCU Tips and Techniques forum might have a thread about it, too.
Old 01-30-2014, 07:09 PM
Jim Thomerson
I've read about it several places, but have never done it. You make a buck of your canopy with enough of a base on it that you have to force it into the bottle. Then you heat and shrink the plastic until it suits you. I don't know how much heat. Maybe a hairdryer or monocoat gun. On one of the forums there were photos of fairly small green plastic canopies done that way.
Old 01-30-2014, 09:08 PM
skaliwag
skaliwag's Avatar
There was quite a few posts about it here on RCU but the new search feature is one of the "improvements"
Old 01-30-2014, 10:41 PM
combatpigg
combatpigg's Avatar
I've had good luck doing searches on Google for info like this.
I've got a [very cheap] Harbor Freight heat gun that would easily do the job.
I can see how starting with a snug fit between the bottle and the plug would make this idea work best.
Something tells me that having a pair of wool gloves on hand would be....uhh......handy.
Old 01-31-2014, 08:35 AM
Andrew
Like CP posted, Google searches are many times more productive. Use the following search term with Google:
shrink plastic canopy site:rcuniverse.com
You may choose whatever search terms you wish, but the site:rcuniverse.com will restrict searches to that one domain. I've found that Google's search engine, when targeting a single domain, is usually better than any other third party search feature.
Old 01-31-2014, 10:44 AM
MJD
MJD's Avatar
http://www.foamflyer.info/canopy.pdf
Old 01-31-2014, 02:18 PM
vauxhall
Carve your canopy buck, cut the bottom end off a 2 litre flat sided PET bottle , wedge the buck in place with a large piece of lumber under the buck, start shrinking with the heat gun. Thats the bit that takes practice, work slowly. It will take a couple of attempts until you get the feel for the shrinking.Both of these cowls and the canopy shown are from soda bottles . Also you can make wheel pant halves, wing tips etc.using this method.
ID:	1964180   Click image for larger version
Old 01-31-2014, 02:35 PM
MJD
MJD's Avatar
What is that on the left, an H-Ray?
Old 01-31-2014, 03:06 PM
vauxhall
On the left is a semi scale C/L Cessna 150. SIG Akromaster wing and an enlarged kit plan Guillows 150. OS.15 FP, 50' lines. Flew great.
ID:	1964185   Click image for larger version
Old 01-31-2014, 09:46 PM
MJD
MJD's Avatar
Oh yeah, once the cowl is opaque it all looks different. Cool, gotta try me one of them canopies.
Old 02-01-2014, 12:01 AM
Boomerang1
Boomerang1's Avatar
Aeroflyte Spitfire in the second pic? - John
Old 02-01-2014, 12:18 AM
vauxhall
Yes it is.
Old 02-03-2014, 03:09 AM
vauxhall
More than one way to skin a cat.
http://www.ffscale.co.uk/page4f.htm
Old 02-03-2014, 06:48 PM
exocet-RCU
That's a cool way to do it.
