"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Screamin' Toucan flies!
Reply
Old 08-15-2015, 03:44 AM
  #126
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 1/2A speed guys were using single blade 5" pitch at one time when nitro was allowed. Now it is 10%, and they rev them higher. I think they are at about 140 mph. Thick lines surely slow them down a lot. I have not been to Muncie now for a couple of years but things look about the same for speeds. They have a pipe. The draggy Profile Proto 1/2A unpiped, were mostly in the 90 mph area, maybe 100 IIRC. Looking at Mike's Profi, I am kicking myself for getting the Fora. It has no way of using a pipe or throttle/cutoff. Oh well, onto a combat plane I guess. I think I will get a few fiberglass props from Yaro next time I see him. The 4.75- 4.75 electric APCs work well for the reedies, but I don't trust them with a Fora, so I guess I have to join the revup club at some point. I think the speed guys are in the mid 30,000 to maybe even close to 40,000 now with the 10% nitro they are forced to use.
aspeed is offline
Old 08-15-2015, 04:43 PM
  #127
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2-1/2 to 2-5/8 x 4-5 is typical one blade these days.
Tomorrow I'll try to get the Toucan to behave for some Doppler passes (with headcam video).
MJD is offline
Old 08-16-2015, 12:01 PM
  #128
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bah! Windy as blazes today. Maybe this evening.
MJD is offline
Old 08-16-2015, 02:49 PM
  #129
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Disclaimer: NOT flight video
Ground run, winds still gusting 20-22mph.
https://www.youtube.com/watch?v=XdNmO6AJVo4
Small high timed engines don't like bench running with high pitch props!
MJD is offline
Old 08-16-2015, 02:54 PM
  #130
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Turns out the engine will stabilize around 27k static on this prop, esp as soon as a I take a deep breath and fine tune it carefully.. may thin and trim some more, but will fly first. Not sure much unloading to expect, but this isn't a proto ukie capping out just north of 100. Should pick up a few thou so long as it gets needled fat enough.
MJD is offline
Old 08-16-2015, 03:04 PM
  #131
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It should unload a bit in the air with the high pitch. Still waiting. Here was too friggin hot, but the wind was not too bad.
aspeed is offline
Old 08-16-2015, 06:44 PM
  #132
Pond Skipper
Pond Skipper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Initial start first steady note - 27.9
Peak pressure drops off right away though
26.4k
25.9
26.6
26.4
26.7
26.3 last steady note
Taking 6 readings averaging 26.38k / 118.7 mph
Should unload 29k nature of the engine 130 mph +
Pond Skipper is offline
Old 08-16-2015, 07:19 PM
  #133
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd expect it will unload a fair bit, this is really high pitch for an .049 and 2-blades. I may have to drop pitch and unwind the engine a lot more, we'll see.
MJD is offline
Old 08-16-2015, 07:34 PM
  #134
Pond Skipper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4.75P on a slick plane doable / practicable should unload more than good sport engines 3k +
Old 10-14-2015, 10:50 PM
  #135
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the plug was leaking around the seal and that's why the last couple of outings were such a headache. Reassembled the engine this evening, put the plug back in and flip flip.. hmm, that doesn't feel great.. losing compression at TDC. Where is it going? A few drops of WD40 around the plug base and ta-da! Tiny bubbles..
Swapped plugs.. leak gone. Tomorrow I'll fire it up with the new trimmed and balanced 4x4.5 and see how it behaves. These Profis are pretty trouble-free.. prolly a simple dum dum like that. Hope so, like to fly it some more this season. Haven't accomplished more than fiddling with it so far this year.
MJD is offline
Old 10-14-2015, 10:57 PM
  #136
Pond Skipper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On all my engines I put some engine oil on the threads helps seal things up of course I wish every small engine had turbo plugs instead.
Old 10-15-2015, 05:15 AM
  #137
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the Profi uses the Nelson plugs. They are pretty much the same as the turbo style. The old TD .049 would loosen the plug on a good smoking fast run.
aspeed is offline
Old 10-15-2015, 05:26 AM
  #138
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a turbo plug head for it as well.. haven't used turbo plugs before.
MJD is offline
Old 10-15-2015, 05:29 AM
  #139
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They come in more heat ranges, if you want to experiment, or the motor is throttled.
aspeed is offline
Old 10-15-2015, 05:48 AM
  #140
Pond Skipper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using a Nelson plug on the AME .061 1/2A Skorch best read after many flights 28770 - 109mph.
Old 10-22-2015, 10:01 PM
  #141
Cross Check
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All,
I have handlaunched the Toucan...
Within 15 seconds of MJD firing it up, he gave me the 'nod' and it squirted out of my hands...
Straight and level, then 45 deg up, then vertical, accelerating all the way...
WOW ! I think humid weather hindered a 'great run'.
That engine is awesome ! MJD can fly the Toucan to a WR I think...
Right conditions/props/ fuel/ Nerves ! ! !
Cheers,
Dave'crosscheck'Fallowfield
Cross Check is offline
Old 10-22-2015, 10:16 PM
  #142
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After I fixed the leaky plug issue mentioned above, it ran out a 20cc bladder like a bear. And unlike before, it can be needled rich without drowning.
I believe Sunday will be Virus day, forecast Saturday is lousy. I'll be at the hangar Saturday afternoon, we'll ground run it there under the doors if raining. Also have to put together the release platform. Using a glider tow release (full scale) and a pulley/ripcord.
MJD is offline
Old 10-23-2015, 05:42 AM
  #143
Cross Check
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
I'll try and 'clear the decks' and get up there Sunday.
Will bring my MagXLS.25 allweather 'UglyStick'.
Before getting my Flu Shot...
I want to be infected with that 'VIRUS' ! ! !
Cheers,
Old 10-23-2015, 05:58 AM
  #144
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll PM or post here to let you know if we're still on.
MJD is offline
Old 10-30-2018, 10:14 AM
  #145
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow - OLD thread!!! Man I take my freaking time getting around to things.. Plus, I haven't really been hanging on RCU for a while, too much time reading and posting instead of doing useful things I guess.
But anyhow.. UPDATE: took the "Screamin Toucan" to the Fall SMALL fly-in earlier this month - flew it about a dozen times, and got a good Doppler pass on the iPhone with the model passing maybe 6-8 feet directly overhead the camera.
Wav-O-Scope says... 37k, and 164mph! That's way faster than I hoped, but yessir it is pretty intense in the air. SIG Champion 10%, CF 4x4.5 prop, and no cowling.. there might be more to go.
Now that it is on crankcase pressure, the engine runs are really steady and pretty much "fuel and go" now.
MJD is offline
Old 10-31-2018, 12:27 AM
  #146
Pond Skipper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow a dozen flights that's some stick time did anyone share a vid with you?
