Ugly back yard fun...........
model looks like lots of fun,Not turning a 5 x 3 is pretty feeble. Unfortunately you bring up the shoulder issue which I fear has likely put an end to my CL days. I have a few tornado 6 x 3 that seem to work pretty well with Cox .049s with their more rounded geometry., the cox props have a lot of cross section area.
Even with the bad shoulders, I'll bet most doctors would see this being good in general. It's not the line tension of a .049 to .15, but forcing the arm to go through the range of motion. Some flyers have a "shoot from the hip" style, but with these little models I use my whole arm to pull back quickly if the line tension starts to feel too light.
The .074 was running too good [to use for C/L], so I'm outfitting the plane for a OS.15 and 52 foot lines. It'll still use a 7 x 3 prop, but what I'm hoping to see from this version is slow and steady flight to practice the stunt pattern with.
The old motor mount was hacked off and a plywood mount glued to the outboard side of the center rib. The trailing edge was banged up, so I fiberglassed .020" MIG wire along the TE.
The plastic 1/2A bellcrank has been replaced with an aluminum FOX unit and the pushrod to the elevator is 1/16" copper coated steel welding rod.
I also outfitted the Hayes 2 oz tank with a hard plastic tube that goes to the outboard wall of the tank instead of using the clunk. The clunk can cause trouble after a hard landing and this tank is buried in the wing.
