"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Cox TD .020 Showdown Video
Reply
Old 06-25-2015, 10:20 AM
  #76
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was going to shoot some helmet cam video of it, but I thought a 24" span model zipping around is going to look like a flying pixel. But I'll do it next time out. This model has survived two terminal dives into snow (one Rx failure fatigued antenna lead, one pilot looking straight up into the sun just as my right foot broke through the crust of snow and I fell over). Now that it is summer and the ground is less forgiving, I'm trying to avoid such things.
MJD is offline
Old 06-25-2015, 11:16 AM
  #77
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Pond Skipper View Post
What engine did you go with for the Cub Kris, looks good!!
I first used a PeeWee with a homemade exhaust throttle but it was very fiddly on the needle and didn't like larger props than the stock one. So the best match was to use a newer PeeWee with diesel conversion. It now spins a 6x3 prop at around 10krpm and will finish the tank on each run. It now sounds so much better than the stock prop at +15krpm too.
Mr Cox is offline
Old 06-25-2015, 11:55 AM
  #78
Pond Skipper
Pond Skipper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike I have seen those on Ebay cheap n easy great for a retro fit for some low stress fun.
Kris have you committed to cutting in to that cowl yet?
Per post #73 I saw a muffler out the bottom any vid of it yet?
Yea diesel has a more scale sound for sure, too bad there are
no micro size 4 stroke engines available for the smaller planes.
I have a few throttle sleeves for the .020 they work great, perhaps
you can add throttle next
Pond Skipper is offline
Old 06-25-2015, 02:09 PM
  #79
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's almost sinful how well the TD .020 version flies compared to some carefully crafted dedicated designs. Typical flight is a minute and a bit of aerobatics and horsing around, then speck it out and look for lift after cutout.
MJD is offline
Old 06-25-2015, 03:45 PM
  #80
Pond Skipper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About 2 months back I was looking at this one a mini EPO for $9.48 - perfect size for a TD .020
http://www.ebay.com/itm/291207797307...%3AMEBIDX%3AIT
Old 06-25-2015, 05:02 PM
  #81
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah there you go. My first instinct on all foam hand toss things is to see how much negative incidence is built in the stab and trim that to a reasonable level. That thing looks pretty similar in size to mine.
MJD is offline
Old 06-26-2015, 12:51 AM
  #82
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I over did it a bit on the first version. It had a fully cowled inverted engine, homemade exhaust (exit at bottom of cowl) with exhaust throttle etc. The model stayed very clean and throttled well enough to stand still and take of from hard soil.
Problem was that it was very sensitive to the needle and didn't run out the tank, plus the small stock prop which didn't seem right for the plane...
The diesel conversion was a quick fix that I meant to do properly at some point. I don't think that exhaust throttling works well on diesel, so I got a helicopter backplate that I wanted to put a throttle into (g-mark carb), but then got sidetracked with other projects...
Mr Cox is offline
Old 07-16-2015, 05:47 PM
  #83
av8rsodt
My Feedback: (23)
av8rsodt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony - Remembered today that you had your F-16 flight.... Watcha think? You are fortunate to get such an opportunity and I know you appreciated it.
av8rsodt is offline
Old 07-16-2015, 07:58 PM
  #84
Tony A.
Tony A.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haven't flown yet. We had two maintenance related cancellations and then I got sick with Bronchitis the week I was schedule to fly. Currently rescheduled for first week of August. I'll be sure to debrief.
Tony A. is offline
