Mini Midget mustang from Airborne models.
#52
So what did that MA 6x4 measure on yours? You did mention you'd measured it.
It's really not news two different brands aren't alike. Heck, some brands differ one side to the other.
#54
There is a guy in England that makes a pitch gauge still. I think the markings are on clear lexan. I just photocopied a Prather faceplate, and machined the rest to match on mine. The odd Prather gauge comes up on the internet once in awhile. I kind of like the MA props, mostly because they last longer when there is a nose over, or no wheels. Revup props were light on pitch too. but they did rev up.
#56
Plane came in, it is too lightly built for anything more than low weight sub .10 engine,
so light it can actually do just fine with a .061. With a smooth running electric it could
handle up to 260w. So light a TD .049 would fly it fine. Possible floater with a TD .020
and a 4x3 for calm weather flying. More power and weight will cause a short life span.
Less canopy and pilot: 178g / 6.28oz with no landing gear as it sits out of the box, primarily
all balsa less motor / wing mount. Many holes to reduce weight, open framed as possible it
was built for electrics from the ground up. Cowl is 23.7g nice finish but not sure if it is nitro proof.
Stickers are nice but then not sure if they will hold up to nitro over time. Workmanship is good.
#58
#60
It's really hard not to get excited when you see a sporty little ARF that looks perfect for ripping around with something out of the .15 drawer.
#61
My Feedback: (66)
I haven't messed with mine much as i was thinking a TD 09 as i bought one for it but a light weight 15 would be good too. You can remove some weight off most 15 size engines like no mounting lugs, back plate mounted and so on. most of the carbs can go on a diet. I think you can get them down to 4 ounces minus exhaust set up but something like this i would just do a tuned pipe header with no pipe cut to fit well.
#62
The ratio of carb to engine size/mass is crazy on some small engines. The CX-11 is one that comes to mind. It is however understandable that there is little incentive for IC engine makers to invest R&D resources into tiny lightweight carbs for engines that are gradually losing popularity, and that are by nature of their size harder to make economically in the first place.
I'll hold off on one of these for now, I don't deserve it until some other projects are finished. If they still exist by then.
