Custom Norvel .074 muffler
I think you will have to make up something on your own. The only choice is on or off. I believe there is a radius that could be mated up to with a couple tapped holes, so it is possible to start with some tubing or whatever.
I have never seen any aftermarket mufflers for Novel engines. It is very easy to make your own though as the flange on the engine is not flat-faced but shaped for a tube. Some thin walled aluminium tubing of the right diameter (eg from K&S) and some JB weld is all it takes.
Here's how I did it on my Super Chipmunk;
