Tee dee .010 micro bipe
CA
Dito what Fred said! Good running engine, would you like longer run times say 6 min. flights?
Per your question yes folks are still actively using them.
I still fly these engines always nice to see the little wonders power a plane!
Here are three of my projects with the mighty TD .010
NANO II - 2nd Trim Flight 2.7x3N Prop / 2.2oz RTF Best pass this vid: 39,244 rpm / 112 MPH
Run time 5 mins. 10sec / 10cc tank / 35% nitro 2ch plane / 15.5in span 28 Sq. In. wing
186.27 km h / 115.74 mph - per doppler Unloaded 39,754 rpm 112.94 mph - per prop calc
Nano I, 2.7x3N prop / 17.5" span
Lil Speedy TD .010 / Test Flight 3x2E Green Drone Prop Best pass cross wind 32,792 rpm / 62 mph / per prop calc.
4.7oz RTF solid pull better loops and faster turns great prop with a throttle. Down wind passes: 33,941 rpm / 64 mph
That plane is DOPE! Nice work, I have a . 010 and a 16 inch Mustang that I still need to finish seeing this makes me want to round up all and the parts and get it finished up.
