This Is Why We Build. (what a crappy ARF)
I knew it was risky but while parusing around Ebay I found an old COX ARF. It's called a Scorpion. Cool little plane kind of looks like a CAP232 or a Super Chipmunk. So I bid on and won it. I recieved in the Mail today. I opend the box and found that the fuse had a bend in it kind of like a bannana and aleron gaps big enough to drive a truck through. Funny thing about the alerons is that in the instructions theres a huge warning about making the aleron gaps to big. I guess origionaly the alerons came unhinged. Then theres a sheet of supplimental instructions stating "we've hinged the alerons for you". Also not a great job with the covereing. Any way it was MFG in 93 and sat on a shelf for a decade so what do you expext. I giong to try to fix the bird and will post pictures when it's done.
Darren
Darren
RE: This Is Why We Build. (what a crappy ARF)
Darren:
If the Scorpion is what I'm remembering it to be, it was for aTeeDee 0.09 and had a wooden fuselage.
And with the 0.09 it was seriously underpowered.
Bill.
Bill.
Heres a pic of the box. Iwas going to put an 09. medalion in it. The only other motors I have larger are old enya 15 and 19. but these are really heavy. Wing span is 40" length is 39 ". Is the .09 too small?
Darren:
That's the one. And the TeeDee 09 RC didn't do a good job in it.
Don't misunderstand, it flew, and didn't fly badly. But vertical wasn't a word it understood.
Go ahead and hang the Medallion, it's easy enough to change it if you want more power.
From what I'm hearing, though, the Norvel 0.074 might be a better choice initially.
Bill.
Bill.
Thanks for the responce Bill. Other than the enyas I do have a .061 norvel but this would be going the wrong way. I'm using the lightest radio equipment I have (micro servos and rx) and should save some weight with the medalion (no muffler w/ throttle sleeve) . But I know thats not much. I knew I should of bought the .074 norvel. Oh well I'll try it and keep my eyes open for a good 2nd motor.
Thanks Darren
Thanks Darren
Hey, Guys. I am currently completeing my Scorpion ARF, too. Mine will have a Norvel .074 (this should cause some real confusion for some readers on this forum: A Cox with a Norvel in it!!!). I am using A Hi-Tec 6-chan. and four HS-81's. The wood is mildewed and the covering is delaminating, but it looks pretty good for a $30 purchase. I should be finished this week-end or next. Pics to follow soon. My cousin is completing his with a Magnum .15, but is having to add over three ounces of balast to the tail.
Regards.
Regards.
My Feedback: (90)
I had on of those back in the 90's and used an OSfp 10 with a Davis head on it. used an 7/7 prop if I remember and really had a time landing with the prop turning Not a bad flyer but then I had to do my own ailerons and did some reshifitng of components to make sure that the balance was acceptable. Bigger heavier motors always require a little rear weight to restore 'balance' otherwise you have a dog.
