Herr Cherokee/074
My Feedback: (123)
MS
Herr Cherokee/074
I bought a cherokee from the classifieds here on RCU, and man what a beautiful airplane! I flew it without the ailerons b/c the rods binding against the other servos. I am trying to figure out how to remedy this problem. It has one servo in the wing for the ailerons, ( very nicely done mod!) but the ail. rods are hitting the top of the elevator and rudder servos. They are mounted lowest possible with z bends in the pushrods. I dont know what else to do. Anyway, for you Norvel lovers, it hand starts after the glowstarter warms the head, (30 secs or so ) and runs like a top. It will sit and idle so low that you almost cant hear it. This is my first Norvel and wow the power and easiness of it is awesome. Any ideas on the ailerons- I know you guys are used to packing all the goods in small spaces. Happy Holidays
RE: Herr Cherokee/074
Without seeing the servo layout, it is a bit difficult to help. Is it possible to lay the aileron servo down in the wing (assuming it is standing up and causing interference)? You would need to make a servo mounting bracket, or alternately shrinkwrap the servo and glue in place with something like shoe goo. Shorten both the torque rod ends and go to shorter servo arms to keep the same aileron travel another alternative. Alternately move the other servos to provide the needed space.
Good to hear about the Norvell...I'm building a House of Balsa Spacewalker with this engine, hope to fly around Christmas.
My Feedback: (123)
MS
I am using HS81's and they are moved out to the sides as far as possible and as low as possible without sinking them into the cockpit floor. Anyway, I am trying to not butcher the inside too much, I will figure it out. The airplane flies great with just the rudder if you can handle all the wallowing and side to side motions. Thanks for your help
NE
I have the same model with the same engine and it is a great flying plane! I too have modified the wing for ailerons. I will post some pix of the wing set up and radio install if it will help ya.
Hec
Hec
My Feedback: (123)
MS
ORIGINAL: CrocEnd
I would'nt even have taken of without ailerons.Nice plane but.
My Feedback: (123)
MS
ORIGINAL: CrocEnd
I have been flying for 40 +++ AILERONS WIN'S hand's down.
Have you flown only RUDDER.
