COX Crank ID?
COX Crank ID?
Here's another part I've had around for some time. I have never owned an engine that it belongs in. In fact I don't think it has ever been used. The crank pin is way too smooth. every once in a while someone will hand me a box of old parts and say "here you'll probably need these some day". Thanks to all of you who have responded to my questions.
TN
RE: COX Crank ID?
Definitely a Cox reed valve crankshaft. Don't have one here at work to measure & be sure but I suspect it's out of an .049. The .020 is shorter than that.
