1/2A Starter
My Feedback: (56)
MS
1/2A Starter
OK guys, what are you using to start you're 1/2 A engines? "Regular" size starters are too big. A flying buddy mentioned using an old 05 car motor and a six cell nicad pack. I have a Cox TD .051 with a Tarno R/C carb but no way of starting it. Any help/ideas will be appreaciated. Thanks.
*rcnats*
*rcnats*
My Feedback: (314)
1/2A Starter
I used to use a regular Sullivan starter with the rubber starting cone reversed. I since bought a Miller 1/2A starter, about three years ago. I don't know whether they are still available. I got it through a link provided by S.M.A.L.L., a discussion email group dedicated to the care and feeding of engine powered planes .25 and below. A couple of years ago, on a very snowy day, I was placing an order at Norvel and they have a starter insert for the Sullivan starter. I bought one, it's yellow. Try the Sig website since they now distribute Norvel. Hope this helps. Reversing the regular insert eventually tears them up.
1/2 A Starter
I modified a Black & Decker Cordless Wizard. Works great with my .049 and .061 Norvels. The local B&D outlet store was selling the Wizards cheap. Took it apart, uncrimped the power leads to the motor, flipped the motor around to reverse polarity and running direction, reassembled, used pliers to jam the chuck/collet on tight, and slipped a length of thick wall poly tubing over the chuck for a starting cone.
Rich
Rich
1/2A Starter
2nd the norvel starter. Even with the cones reversed on the standard starters it would chew up the hole and rubber particles were flying everywhere. The norvel starter turns much faster and starts my .074 quick. But it IS pricey. Worth it to me since I'll be using it more now.
Edwin
Edwin
CA
1/2A starter
I got one of the starters from LMH that they make for their helis. It starts all my "pee-pee" motors up to .10's. Was in the ballpark of $39.00 .
so many toys--not enough time to play!
My Feedback: (90)
1/2A starters
I usually use my starter with 6 volts as that is fast enough to get the motor going and slow enough to feel the resistance of flooding. Also I usually prime the motor and usually a quick tap has it running. On all these llittle motors remember that the shim behind the thrust washer will wear out so watch and replace as necessary. Otherwise you'll be pushing the crankpin back into the backplate [Norvel]
CT
1/2 A starters
I know of three commercial starters: (1) Miller R/c makes a really nice one, very nicely made (2) Norvel peddles one, I've seen them on the LHS shelf but never handled or used it (3) Sullivan has just advertised one, I don't know if it's made of 'unobtanium' or whether it actually exists. Astro Flite used to sell one a zillion years ago, they work very well, but I can't imagine finding one unless an owner wants to peddle it off. I own two of these, the Miller and the Astro. Miller's the class act for product quality, but I've never used it - - the Astro works just great.
Cheep way to use your exisitng starter for engines down to .010
Try this - it's cheap and easy to do, and it won't break rods and cranks if the engine floods. Get any starter cone for your existing starter and fill the larger open end with GE silicone rubber. It'll take a week or so to dry fully, but when it's hard, find the center and cut out a LITTLE piece for your nose cone to fit into. The smaller the center hole the better. If the engine seizes up, the starter cone will just spin around the nose cone on your engine. If you leave the smaller hole on the other side of the starter cone empty, you can use it for smaller spinners like on .10s or .15s.
FYI........................
1/2a Starters....
Hi,
Just found this forum and it's super. I race 1/2a's in our clubs monthly 1/2a pylon races, been doing that for about three years. We have about twenty regular racers and everyone uses an electric starter of some sort. I've seen the 1/2a cones used on the larger starters with some success. Newer guys are buying the Norvel units, And probably the most (including myself) are using the Miller unit. IMHO the Miller is the best available that I have seen. A little bit spendy, but bullet proof. Good Flying!!!
Best Regards,
Jeff Leavitt
Best Regards,
Jeff Leavitt
Miller 1/2a Starter...
My Miller starter came from the lhs. I looked on the starter to see if there was an address label on it, but it is warn off sorry... You might try Sheldons Hobbies, I would bet they would have the unit. It's worth the look...... Rgds.....
Jeff......
Jeff......
