matchless 3D, fuji tank & TTGP07
Hi, my name is Marius. I live in a town called Secunda in South Africa. I am in the process of building a Half Wit - covered ready for assembly, waiting for the AP Wasp from Tower hobbies. I have been waiting for 30 days now.......[]I need more info on how to make one of DICKEYBIRD'S Fuji tanks. I tried the search facility without luck, my computer skills suck!
I have a GP07 that is very, very sensitive to the fuel level inside the tank. Rich with a full tank lean cut out at half........ Anyone that has a cure? Tech article on Norvel website says that over compression is the biggest culprit in engines cutting out.
RE: matchless 3D, fuji tank & TTGP07
ORIGINAL: hasallthenamesbeentaken
dave
TN
The finished tank:
Also, here's a good way to stop tank foaming if you have a box-shaped tank compartment. You drill a 1 1/8" hole in some foam with a holesaw IN A DRILL PRESS....DO NOT TRY THIS HAND HELD! Measure your tank compartment and cut the foam block about 1/8' larger all over. Glue the tank into the foam and stuff the whole thing into the fuse. The foam on all sides insulates the tank very well! This method won't apply to your HalfWit since it's a profile.
Good Luck!
Good Luck!
Hi Marius,
As mentioned in an another thread it sounds like you are losing the pressure from your muffler. This can happen a few ways: a pinhole in the tubing, a leaking tank, and what I ran into: the wrong internal diameter tube to carb.
The inlet to the carb is very small and about the only tubing I found to work well is the stuff supplied with the engine.
Assuming you are using the supplied tube for the carb, I would pull the tank out and just pressure test it by holding it under water and blowing into the muffler line while blocking the carb line, and watching for bubbles.
BTW, here's a gratuitous pic of my Zero Seven with TTGP07. It's lasted longer than any of my other aircraft simply because it's small and always works
John
John
Hi, thanks for the replies guys. I received my Wasp and it has done 40 mins. of break in - runs great! The Half Wit is assembled (except for the rudder - got to get more cyano hinges). I added a lot of ligntening holes to the original design. It looks very cool, don't know however if it really helps, the pile of round balsa discs that came away weighs nothing
Had some fun flying last weekend. Crashed a 2 channel plane while flying backwards! Yes you guessed it, I was caught by a sudden change in weather. The GP07 (I use it with the throttle jammed open) ran better by the second as the cold wind started blowing. It used up the complete tank inventory with me wacking the sticks trying not to crash. Luckely the damage was slight, and yes, I was humming "Riders on the storm" by The Doors driving home from the field.
