contest entry for Flyinrog
Inspired by Big Al's mustang and Matchlessaero's work and his chipmunk, I am attempting to build an .010 powered Chance Vought F4U-Corsair..AKA Whistling Death,,size is based loosely on Match's chippy ,but it may turn out to have a pee wee .020 instead, it also may not be blue but colored with what I have on hand,,still looking for a cheap digi camera, but if I dont find one I will buy a disposable cam and have it developed on disc so I can get pics on here...it is
ws ~20"
fuse length is 15.5"
2 channel R,E
the wing spar has been a b%i&h so far, have cut out the fuse sides, and 75% of the wing
ribs are done,,did a little library research and a computer google to find the wing angles,, but it is all based on Match's sized chip and now it's all on the TLAR trail.
Found a guy building an %82 size flying kit for his personal use,,I dont mind building and/or crashing a plane... but I damn sure wouldnt fly IN anything I built...Rog
ws ~20"
2 channel R,E
RE: contest entry for Flyinrog
Hi flyinrog. Like your ideas. A Corsair would be way cool.
I do have to take exception to your closing comment though. "Found a guy building an %82 size flying kit for his personal use,,I dont mind building and/or crashing a plane... but I damn sure wouldnt fly IN anything I built...Rog "
I think I represent that remark :-)
Take a look at my other project:
http://www.newtech.com/n14se/rv7.html
TX
How large is the cowl?(diameter) I've thought about an .020 size, but never got around to it, I am building currently an .049 size. I did draw up the plans for a Bearcat for my .020, but decided not too because the cowl was nearly as big as the propeller, I think it has 100 sq inches, I guess now with the super micro radio gear I could reduce it even more. I've done 80 sq in. planes before, but not a scale type, just a stik type, so I allowed 100" for the additional weight.
Here is a picture of the Corsair along with a scratch built ACE messerschmitt I am building, the outboard wing panels are in the background and the plans (RCM) for the Corsair are underneath. The wing is way too thick for my taste, and after outboard panels were built and all the pieces cut, I've been thinking about a redesign on the wing, make it easier to build and thinner. The center section doesn't bother me, but it doesn't thin out much at the tips, I think some the designers used to do this, I've build some control line planes that the wing is 1.5" think in the center and at the tip even though the chord went from 10" to 6". I'm still debating, also, if I rebuild I will use the center rib as the template so I don't have to build a new body, and I will cut a 1 piece ply spar, or do a laminated balsa spar for the center W shaped section. I built a jig for the body to hold all of the formers while I skinned it, the article with these plans is very sparse on building info, but the pictures of the finished product look good.
havent made the cowl yet, but around 2 inches,have no drawn out plans am "winging it" (what a really bad pun) but it is all done by eye...stand wayyyyyy off scale..it should be interesting,, I didnt know rcm had the corsair plans,, I have the catolog somewhere but cant find it .......yours look nice, good job so far...Rog
Sounds really cool Rog!
Are you going to do it in a Navy scheme, or is it gonna be a tiny Reno Racer???
If you do it in a Navy scheme, are you gonna build a little quad .061 powered Carrier for it to fly from?
